AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Chad B's TV rankings
Chad B's TV rankings - Page 17
post #481 of 506
Originally Posted by pneumatic View Post
That is the total opposite of what I found on the 58C7000. Gray ramps showed ZERO banding on mine. Even the scrolling gray ramp moving across the screen did not have any banding. Maybe the 6500 is different in that regard?
Neither the LG or the C6500 show any banding on the standard gray ramp test patterns that go all the way from 0 to 255 across the screen. That ramp covers too much range to expose the banding. In fact, that ramp is pretty much useless as a diagnostic pattern in my experience, at least for any modern display.
You need a more gradually changing gradient to expose the differences. You might find such a pattern in a movie, for example, if there is a uniform wall in the background with a dark subtle shift in luminance from right to left. Then the bands will be evident on the Samsung, and the big ugly dithers on the LG.
post #482 of 506
@rpauls
Do you have "Blade Runner" at Blu-ray-Disc or HD DVD at home?
I think, I knew, the transfer had banding besides the ugly DNR, but now I'm not so sure, that it isn' the LG-Plasmas fault.
I was able to get rid of the banding at Decker's door when Rachel visits him the first time, but I have still bandings in fires, lamps, skies and the dust in thy sky in the opening sequences, also the light/dust in Sebastian's house right after Decker kiled Daryl Hannah.
EDIT: And btw, I got banding with my first calibrationexperiences with the 20point-calibration in the 256 AVS709-greypattern, so it is "possible" to get banding even there.
post #483 of 506
The Blade Runner Blu-ray disc is one of the most impressive transfers I've seen. I have the full blu-ray collection. It doesn't have any banding on my Plasma that I've seen. If you have banding problems, more likely it is a setup issue or limitation with your equipment.
post #484 of 506
I mean the Final Cut, that is plagued with lots of DNR and a medicore bitrate of only 17Mbs.
I would be happy, if you could check dust, fires in the opening sequence and lighthalos in Deckards appartement and Leo's room for banding.
post #485 of 506
So there are two versions of Blade Runner on BR? 17Mbps does seem to be too low. Aren't they usually in the 25-35Mbps range?
post #486 of 506
http://www.dvdbeaver.com/film/DVDRev...laderunner.htm
There are even drops down to 12Mbps. Singlelayer-BD.
And the banding is indeed in the transfer-> http://www.dvdbeaver.com/film3/blu-r...blu-ray_1x.jpg
post #487 of 506
Minor update: took 2 points from LG 55LHX for the dirty screen effect issue.
Also updated the review index to include the latest 2011 reviews and the Swans loudspeaker review.
post #488 of 506
3/21/11
Originally Posted by Chad B View Post
I am hoping to have a review of the 60PZ550 posted in the next few days, a week at the latest.
I only used 2D mode. The set was fresh out of the box. The owner is local, so we wanted to go back after a few months and see if there was a significant change from the break in process.
Really looking forward to this review Chad! Bring it out already
post #489 of 506
I too would love to hear your findings on the pz550 series...
post #490 of 506
+1
post #491 of 506
Originally Posted by rpauls View Post
Too bad the manual is In German. I would love to learn more about this, and exactly what these adjustments are doing. VY and VA sound like voltage adjustments, but I have never heard of pots called set_up and set_dn.
Can you tell me a little more about what each adjustment does? Do all 4 affect MLL? Any way to translate that manual? Electronic form or paper?
All the documentation is available in U.S. english
This is the complete LG plasma Panel Alignment Book (quick reference), latest version (03/31/2011): http://136.166.4.200/contents/Displa...t_Handbook.pdf
LG U.S. got the explanations from the complete Training Manuals of many plasma models, and they have arranged that book. Read it carefully before start to do something. If you have never done such things before, it is better to have a look for an expert TV tech friend. The right way to arrange the tuning work, is to use a big mirror. Put the TV screen in front of the mirror and look at the mirror during tuning. Use only full plastic screwdrivers (easy available and very cheap) and remember that there could be high voltages on some circuits, so be careful. It is like to work on tube amps, you know? Only a bit more difficult because you are working on big screens, and that's the reason why you need to use a mirror (for safety reasons, at first).
For many plasma models, complete informations and training manuals (very useful) are also available. On this page there is the list: http://136.166.4.200/SubPages/Directview_PDP.htm
clic on the model you are interesting for, and on the left of the new page you will find the docs available for download. There is even the new 50PZ950 and PV450 models, as well as the PK950 and 750.
With such informations available, I think LG plasma are well worth a look. I'm going to buy a 60PK980 (same of 60PK950) during the next days. Now it has a very good price in my Country (1170 euro including shipping) and it is the right time to buy it. I'm not interesting in the actual 3D stuff.
'sorry for my bad english, and best regards from Italy
Mauri
post #492 of 506
Chad,
in case you are interesting, here is the same stuff for some LG LCDs: http://136.166.4.200/SubPages/Directview_LCD.htm
post #493 of 506
Mauri
I don't see my 2010 PX950 model in any of the pdf documents from this link?
post #494 of 506
For the panels alignment, the boards of the PX950 should be the same of the PK950 model. The procedure is always the same and the voltages are present on the label of each individual plasma panel, as explained in the Panel Alignment Book. Take a look at the PK950 procedure, and you'll understand how it works.
The pages of that web site will be updated, as well as the docs.
BTW, I don't think this is the right thread to continue to speak about this things. But I don't know what thread could be the right one
post #495 of 506
dear chad B, did u review the samsung plasma d550 or planning to review that? (if yes,plz give me a link)....i'm very new to this forum & this is my first post... if u can guide me in this,i will feel much thankful!
post #496 of 506
Chad,
Thanks Mauri, I appreciate the info!
post #497 of 506
I haven't had the opportunity yet.
post #498 of 506
Mauri
Thanks for this info!
I don't see the LG 60PK550 listed, but I do see the 60PK750. Is that the closest match to the 550? Are there any significant differences?
post #499 of 506
The 50-60PK550 are listed in the LG plasma Panel Alignment Book (first link I gave you before).
post #500 of 506
Chad, maybe I'm doing something wrong, but the link to your overall table of all displays reviewed is missing from your signature (I can only link to your 3 most recent reviews).
post #501 of 506
are u looking forward to it?...if yes, any time soon?
post #502 of 506
Thanks, I fixed it.
post #503 of 506
I would be happy to, but I don't know very far in advance what I will have the opportunity to review.
post #504 of 506
Are there any updates in your rankings?
post #505 of 506
Please update your picture quality chart when you have time. I'm interested in seeing how the latest models you've reviewed stack up against the others. Thanks.
post #506 of 506
Thanks. I have another busy week on my calibration tour, then I have to meet with my friend/web guy to be trained on how to update my new webpage. Hopefully soon after that.
