AVS › AVS Forum › HDTV › HDTV Technical › Coupon Eligible Converter Box (CECB) › digital channel list
post #1 of 9
Is there any place I could get the fill digital channel list in my local area(Los Angeles)?
Because I have spent so many time and sp tried so many spaces and still cannot find Zenith DTT 901, I bought the channel master CM-7000 yesterday.
Now I found I cannot get 2 channel that I used to watch a lot - "Food network" and "TBS" in the channel list that I just searched(have tried several times). I am kind wondering if these 2 channels cast in digital signal so far ??
It's really frustrated for me and I also just found channel master CM-7000 doesn't have Analog Passthrough function....
post #2 of 9
OTA with a map of directions and signal strength, look here: http://www.tvfool.com/
post #3 of 9
Converter boxes, like the Zenith & Channel Master are for OTA channels received with an antenna. Ask in this topic for local OTA stations in your area: http://www.avsforum.com/avs-vb/showt...php?p=17050909
Food & TBS are not OTA, and are only available from a hardwire (cable, fiber, IPTV) or DBS provider.
post #4 of 9
Um Food Network and TBS are CABLE channels of course you're not going to find them OTA.
post #5 of 9
"Food network" and "TBS" are not currently broadcast OTA, so a CECB will not receive them. If you have cable TV service, then do not use the CECB.
post #6 of 9
http://www.rabbitears.info/market.php?mktid=2
Click on a station name to see more information like subchannels, which network(s) it belongs to, etc.
post #7 of 9
Antenna to Splitter, split to CM and TV, then CM composite or S-video+audio to TV.
If not enough power for the split, a VCR can work as your pass-through: Antenna to VCR then VCR RF out to CM. VCR composite to TV. CM RF out (or S-video+audio) to TV. The VCR becomes your analog tuner.
Consider: Best picture in this order:
1) S-video
2) Composite (RCA connectors; typically a red, white, and yellow set)
3) RF (coax)
post #8 of 9
"not currently"? I'm not aware of any plans for them to EVER be broadcast OTA.
post #9 of 9
Maybe Kelly used to get them courtesy of local cable system leakage that has now been remedied?
