I got a PM, which made me want to elaborateon this idea for a bit. I really gained some new insites to accoustics from talking to Ted White last night. I finally got it through my head why making hole in the ceiling is such a problem. The sound escape the envelope. We use backerboxes for lights to prevent exactly that! But who uses backer boxes for their HVAC runs? Anyone?
Here's a bit of cut and paste on a PM reply I sent which goes through a more detailed explanation as to why I think this system is superior to ceiling vent systems.
When I talked to Ted White last night, he explained that a major short coming in vent design is that when you cut a hole in the ceiling for the vent, the sound can then go straight into the room above. That's what we are tryint to prevent. He said in extreme cases people actually build VENT backer-boxes, meaning the hole length of flexpipe is in a backer-box. I thought about this and then figured I could essentially make a backer-box for my flexpipe, but run it vertically (ie in the colums) and that would allow me to get the vent into the floor. This is not a concept I have seen used before. The difference between my design and most others is easy to see from an accoustic standpoint. Place a HUGE speaker right under a typical ceiling vent. Since that vent represents a hole in the DD+GG, the sound will go right through the vent, through the top of the flexpipe and continue straight up into the room above. Now place a speaker over my floor vent. Sound goes in, hits the concrete and disperses and gets cought in the riser insulation. Very different situation. The hard part was figuring out how to get the vents down into the riser.
