Originally Posted by thrtnastrx
I am using a Yamaha RX-V2045 with three zones. The main zone is my living room surround sound, second zone is my backyard around the pool area, and my third zone is the music room where I have Cerwin Vega XLS-215's. The second and third zones on the Yamaha RX-V2065 don't seem to have any settings that I can change to enhance the music (only has + and -) so that means when I turn the sound up really loud on zone 3 (CV's) the sound is distorted. So my question is do I need to add a crossover so I can remove the bridge on the 215's? I found this model on eBay PylePro PYX3X but I'm not an expert on home audio so I'm not sure if it will work or if I need one or two or if this is a piece of junk. Or should I use the pre-outs and a seperate amplifier for the CV's? Hopefully someone can give me some advice on how I'm supposed to set this up so it sounds better at really high volumes.
You could simply test if room correction fixes it by connecting those 2 speakers as the only speakers in zone 1, run YPAO, and check the resulting sound. Of course afterwards you'd have to reconnect the surround speakers and re-run YPAO, so it's a bit of work. If room correction helps a lot you'll need an additional amplifier with room correction AFAIK.
