I've noticed some channels coming through in a smaller format. It's like 16:9 but smaller. I've seen this done with ads but not regular TV very much. But after Comcast pushed out some updates back on 2/18 I've seen this more. Not sure pbbear if this is relative to your issue.
Your notes say you switched from 16:9 to 4:3. So apparently no matter how you set it you are not getting 16:9? What process are you going through to make this change.
The Guide and Menu items can also be displayed in 16:9.
Follow these instructions:
(RNG110 manual here with these and other instructions:
http://www.midcocomm.com/classlibrar.../files/191.pdf. Page 11 for the instructions below.)
Here:
Putting your set-top into user settings mode
1. Make sure that your set-top is turned on (POWER light is green).
2. Press the POWER button on your remote control (POWER light goes off), then press the Menu button.
You should see the USER SETTINGS menu, shown right, on your TV screen.
3. When you have finished making changes (see pages 11 through 15), press the POWER button to remove the
USER SETTINGS menu and return to normal viewing.
About the TV Aspect Ratio
The TV that you have connected to your set-top has an aspect ratio (width-to-height ratio) of 4:3 (basic/
standard) or 16:9 (widescreen). You must set the appropriate TV Aspect Ratio (4:3 or 16:9) on your set-top, so
that it is compatible with your TV.
Setting the TV Aspect Ratio
If you have not done so already, put your set-top into User Settings mode, as described above.
Press the U or D button on your remote control and highlight TV Aspect Ratio on the USER SETTINGS menu.
1. To change the TV Aspect Ratio, press the R button.
The TV Aspect Ratio menu, shown below, appears on your TV screen. On the menu, the current setting
(4:3 or 16:9) has > in front of it. Also, whenever the current setting is displayed, the DATA light will be
lighted on your set-top's front panel.
TV Aspect Ratio
4:3
>16:9
2. Press the U or D button to highlight the TV Aspect Ratio you want.
3. Press the OK/Select button to confirm your choice and change to that TV Aspect Ratio.
