Originally Posted by BrentHD
I was annoyed with the RNG110 when I first got it because my TV had trouble tuning channels when going from HD to SD channels. There would be a blank screen and a "video not found" warning for a second before the new channel would display.
The fix is to change the TV display properties in the User Control menu [User Settings - Power off > Menu (press < 2 sec)] to just one input setting. In my case the TV's native display is 1080i. By setting that as the only one as YES and then NO for all other resolutions I was able to get faster and smoother channel changes.
Thanks for this suggestion - it seems to help a bit.The TV my rng110 is connected to is a 720p, but it accepts 1080i, so I wasn't sure if I should set it for the native resolution or the higher one; I will have to experiment a bit - but setting to 720 *has* eliminated the pause between channels (I never got the "video not found warning" just a delay, which I thought was the channel guide. I may go back to component, since some of the delay between channels may also be due to HDMI negotiation.
