AVS › AVS Forum › Video Components › Video Processors › :: What will processor do to for me, solution?::
post #1 of 16
Hello,
I am getting into video processing, still a rookie though.. Are they worth buying? My fios on some SD channels is blurry (Verizo FIOS claims that they have best picture quality, and it is a BIG lie!!).. What will the processor do for me? Will it make my Blu ray even better? Sorry for the questions!! I am looking to make my setup better altogether..
Cheers,
Robbie
post #2 of 16
Hi
I bought a DVDO EDGE only for Blu-ray and the difference is night and day but am running a 12ft 2.40 screen but It need a lot of help, If you would to buy a EDGE you will notice your SD DVD will look a lot better because the EDGE use 2010-VRS chip that is top of the line right next to HQV.
It made blu-ray better for me is I have a older player and in the past 2 years they have improved on the Picture quality by using VRS or HQV video Processor on blu-ray.
Go for the EDGE you will Love it.
post #3 of 16
Hi what i would like to know i am using a Jvc-Hd1 projector used about 130 hours if i where to buy a Dvdo Edge how will it improve the picture and i havent got the projector calibrated for that reason might as well get both done if i bought a Dvdo Edge.
Regards Lino.
post #4 of 16
Regards Lino.
Hi
What ever you put through the EDGE it comes out better at the other end so yes it will improve your Picture, And now the EDGE support Deep Color Now so it will go well with your JVC PJ
What are you putting through your PJ.
post #5 of 16
Thank you!! Right now you can pickup the EDGE for $499, pretty good deal if it will make my picture better. Does it have a setting for motion? i love the effect of smooth motion, almost fluid-like you find on some PC dvd players like powerdvd with motion enhancer..
post #6 of 16
No.
post #7 of 16
It does not do motion but if you get one you will love it it is awesome
post #8 of 16
Thanks Hdblu the Dvdo Edge prices have dropped around $950 at Clef Hi-Fi in melbourne but some retailers still sting u around the $1500 + at the moment cannot afford i am buying a new Philips Pronto TSU-9400 Touchscreen Remote Control and the Edge should be the next item on the list.
Regards Lino.
post #9 of 16
Regards Lino.
Hi If I was you I would wait on your Philips Remote and get the EDGE why the EDGE is for a limited time Only and they droped the Price down to $999. I was talking about this to my Hi-Fi-Deal and that was about 4 weeks ago am surprise it is still for $999 to tell you the truth I would still pay $1600 and I would feel am stealing it, as you know they charge for the VP50pro 6k and it use the same VRS chip in. but the VP50Pro is for more calibrating.
I would not wait more then two weeks for the EDGE
post #10 of 16
Hello Hdblu even when the Dvdo Edge wasnt on speceial Clef Hi-Fi quted me $1050.
Regards Lino.
post #11 of 16
Regards Lino.
Hi the normal price it $1599 in Australia my be they come down, $1050 is what I payed for mine I bought my from New York when I was over there.
post #12 of 16
I'd love for you or someone to PM me where and how I can get one of these new, and preferably legit, for that price.
post #13 of 16
I found it on froogle price search, unfortunately they are out of these units.. I will do my power search. I only deal with legit stores, and Manufacturer part no.
post #14 of 16
please guys: limit your posts to technical issues...
post #15 of 16
Sorry.
post #16 of 16
Okay, here is my conclusion when it comes to DVDO EDGE... Aftert playing around, twaeking in all various ways, EDGE did not improve my fios, certain channels were no different, edge improvement was somewhat noticeable, but also was the artifacts. I will return the unit, it is not worth $799. Perhaps a larger screen than my Wega 40" XBR, I honestly did not see improvement, I dont know what is the big hype about!...
  Back to Forum: Video Processors
