David, thanks a million for the time to respond to me
I already had that setting changed. In fact I called Denon today, and they walked me through my entire setup, and it was all setup as best as it should be. I even did a initilaize reset per the Denon rep's recommendation, set all the settings again, and still it didn't work.
What I did notice is on my 2500, the TRUE HD light did not light up when I tried Risky Business today... On the 4010 it played the audio track 1 which was 5.1, but it wouldn't play in True HD, when I switched it to audio track 2 on the remote, it left DD 5.1 on my Krell and went to DTS Neo6 which is a matrix 2 channel mode... I did the SAME setup on my 2500, and what I again noticed (mentioned above) is that the logo on the unit itself stayed on DD 5.1... SO the only thing I can deduce is that the DVDO will not allow the player to push BD codecs to it... I know the 2500 plays BD Codecs when it was hooked to my 4808 AVR... now that it is going to the DVDO as a switcher, it won't...
So, since 2 similar machines made by the same company and hooked up to the same DVDO switcher both do not play BD Codecs, it would make sense this was the problem... I hooked up the 7.1 analogs today after figuring all this out and it sounds great. On Risky Business, I honestly can't tell much between DD5.1 and TrueHD swapping between the tracks, but at least I know it is setup for other movies...
On to another problem that reared it's head after doing all of this, my right rear channel SBR on the analogs doesnt seem to be outputting much. I tried Transformers 3, Tron Legacy which are both 7.1 movies, and I have SBL output but no SBR... I swapped the RCA inputs thinking I had a bad cable, same thing, SBL, no SBR... SO I thought maybe my amp or speaker was the culprit... I ran a 5.1 surround sound cd which will play on both my rear and side surrounds (per the Krell setup) and both the rear speakers work great... This leads to a problem with the 4010 not outputting the SBR channel properly... (I came from car audio world, there's a lot of trouble shooting sometimes, hahaha)...
Does anyone have a similar problem with their analog out puts? Would doing a software upgrade fix this? This is a BRAND new unit with a 9/09 MFD, it was a display that was never hooked up at a dealer... I doubt it's had any updates. Hooking up internet to it is not to trivial since it's in a bedroom that doesnt have hard wire internet. my XBox and PS3 are both wifi... Should I run a long @%# cable from my downstairs up to it and get it up to date? Im one of those guys if it's not broke, dont fix it... worried I do an update it might make the transport stop reading discs or something. lol
I guess I will try to get this fixed and hope for the best.
