AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Denon DBP-4010UDCI
Denon DBP-4010UDCI - Page 10
post #271 of 1124
Originally Posted by Azz View Post
Well my 6 channel cables finally arrived today! Australia Post strike added basically a week to the delivery time. Ive started holiday's so have had a bit of time on my hands - Anyway, Ive hooked it all up and am suitably impressed!
SACD is in my opinion is up another level on what the 2930 reproduced.
As Ive got a multichannel Pre Amp I'm also toying with the idea of watching a few BR's using the 4010's onboard processing and bypassing the AVR (excluding video switching). It's not easy to do comparisons though I might give it a go.
good to hear yours arrived az, god only knows where mine is at, was put in the post apparently more than a week ago ! normally you get this kind of the thing next day or so. hopefully comes in tomorrow in time for the little re-arrange I've got going on !
good to know analog wise it is doing well in your system, sounds really interesting what you have in mind with the 6 ch pre of yours !
post #272 of 1124
Originally Posted by MrJonas View Post
Sounds very interesting. I'm very interested of how it goes for you because I'm going to use a 5-ch analog input. I'm going to do the same test at a Denon dealer with a 3k reciever e.g. Denon, Nad etc. I think it will be hard to hear differences but very easy to test, just change input. What do you have for amplifier?
Amplifier is an Elektra Theatron 7. Locally made (Australia) item that delivers the goods in spades.
7x185w at 8ohms, or 7x220 at 6 ohms. Don't ask me what it does into 4 ohms..
When you change inputs on my pre it does a soft volume down then soft up with the new input. I understand that this is a characteristic of most Bel Canto's. Effectively it takes about 2.5 seconds to have the volume level to back what it was after an input change so it's not as easy as doing an AB with a lot of other equipment.
post #273 of 1124
post #274 of 1124
Originally Posted by markrubin View Post
Denon reps came to my house today:
http://www.avsforum.com/avs-vb/showp...ostcount=15353
Awesome sevice Mark.
I am proud to say I have the 4810 and soon the 4010...
post #275 of 1124
Yes that is awesome service.....
I'm sure Denon responded so well because Mark is a AVS member
On another note could some other 4010 owner give Iron Man BD a try.
I'm unable to get this title to work on my 4010.
Works fine on the OPPO.
This is the first movie I've had issues with on the 4010.
DreamCatcher
post #276 of 1124
well even better news
after hooking the AVP back up I decided to give it one last try
3 lights
post #277 of 1124
DC - Iron Man BD works fine on my 4010.
post #278 of 1124
3 lights
That's Great News!!
post #279 of 1124
3 lights
Now just don't turn them off.....EVER
DreamCatcher
post #280 of 1124
3 lights
That is great news, Mark! Do you have any idea what the problem was?
3 blue lights!
post #281 of 1124
hmm, that is good news that it worked, but still remains a mystery doesnt it ?
good effort on denons part,
Denon reps tried everything: settings/ cables/ swapped units: everything with no luck except to agree this is indeed a firmware issue and they need to resolve it
atleast it explains I'm not imagining things that tried what seems like everything and it doesnt work.
Hopefully they release an update for the avp or the 4010 or both
so that just works
one other curious thing I found today, when in standby, when not using the unit, the little fan on the back runs all the time. was a little suprise for me. it does make a tiny little whirring noise as well, lets hope doesnt get any louder ! or might become noticeable ! I am running the unit with all power save modes switched off, perhaps with power save on the fan switches off. but then it will take longer to boot up
post #282 of 1124
I'm *really* close to pulling the trigger on this unit to replace a DVD-2900 and BDP-S1. I have tried to register with ci.denon.com several times but never receive an e-mail response.
A few questions:
1) The manual states the RS-232 port is for "future expansion" ??. - I assume this means the RS-232 port is NOT currently active - is this correct?
2) What is meant by "expansion"? (RS-232 is commonly used for device control).
3) If the 232 port is active, is the serial protocol compatible with the 3800? - If not, where can one obtain a copy of the protocol documentation?
Jeff
post #283 of 1124
A few questions:
Jeff
cant answer the r232 questions, but a denon 2900 and sony bdp-s1e ? I had both players
the 2900 a lovely player really, and you'll find the 4010 every bit as good, well quite a bit better actually. going from the sony to the 4010 will feel like moving from a tri-cycle to a race car ! the 4010 better for DVD, and BD as well for nto only PQ but plus with Audio given the 4010's ability to bitstream and internally decode all audio formats.
you'll be very happy in an upgrade to the 4010 I think.
post #284 of 1124
DreamCatcher
My 4010 arrived yesterday, and Iron Man BD plays fine here
Denon DBP-4010UD (European model)
Iron Man BD (Danish/European edition)
post #285 of 1124
pays fine here too, aussie edition on both player and disc
post #286 of 1124
my own thought is some of the problem is with the DL4 cable: the only thing I did last night was reseat it. Not sure an ethernet jack is the ideal connection device for DL4
I have the expensive DL4 cable coming in for my own little 'shootout' ...don't worry: I ordered it from Amazon so it is easy to return it
post #287 of 1124
hehe, as a mod hope your ready to put a lock down on this thread !
the denon link cable supplied in the box is a cat5 cable which is what I am using. can try a cat 6 if you like ! bandwidth wise denonjeff has explained denon link has got plenty up its sleeve !
need to keep in mind for the 3 lights the denon link cable is only used for the clocking signal not for the hdaudio itself which still goes over hdmi I understand.
that said, by all means be our guest and blow our minds and let us know if the denon link cable makes a difference
post #288 of 1124
Does anybody have a link I can use to report issues to Denon?
I still can't get Iron Man BD to work on my 4010
DreamCatcher
post #289 of 1124
DreamCatcher
Hi DC.
Is it worth hiring a different copy to see if its the disc?
Not sure what the service at Video stores is like where you are though most over my way, if you have a problem with a disc and take it back pretty quick they'll give you a store credit pronto.
post #290 of 1124
I am a skeptic as well but I want to try it for myself
post #291 of 1124
I can confirm that Ironman does not work on the 4010. At least not our version. Guess we better call them.
post #292 of 1124
3 blue lights!
I had a similar issue when I hooked up my 4010 to the 4810, I couldn't get the blasted third light to come on. In the end I did the following:
With both units on and AVR-4810 receiver on the DBP-4010 input:
i) On the DBP's setup menu go to Denon Link and set to off.
ii) On the AVR's setup, go to input setup for the DBP and set HDMI only (i.e. remove DLink).
iii) On the AVR then switch to another input and switch back to the DBP input
iv) On the DBP go back to the set-up make sure that HDMI audio is set to bitstream and then re-enable D/Link 4th - accept the HDMI Control prompt.
v) ON the DBP come out of the menu and press the HDMI Mode button on the remote -> HDMI On.
vi) On the AVR menu, go back to the DBP input and re-enable D/Link.
vii) Put BluRay disc into DBP and hopefully this time you'll see the illusive third light!
post #293 of 1124
Maybe they should make it a little easier?
post #294 of 1124
is right
Interesting that Iron Man BD doesn't work for you either
I've checked that my unit has the latest firmware update, it does.
I don't think getting another disc is the answer as my Iron Man BD works with my OPPO, Samsung and Panasonic bluray players.
joerod are you going to call or should I?
DreamCatcher
post #295 of 1124
So it doesn't have anything to do with HDMI Control settings?
DreamCatcher
post #296 of 1124
DreamCatcher
Iron Man is a problematic disc. My Panny BD-55 wouldn't play this disc though also when it was first released. A workaround that works is ( you must be the owner of the OEM disc) just make a backup of your OEM disc and it works perfectly:. This way you may watch your movie (it looks and sounds fantastic on the 4010) during the holidays and wait it out for a firmware upgrade. Hope this helps. Happy holidays to all..
post #297 of 1124
is right
DreamCatcher
Let's both call today.
And my Ironman disc works on my other 9 playrs I have here. It is the 4010 (has the latest update as well)...
post #298 of 1124
Funny thing is it works in the 1610.
post #299 of 1124
I tried to achieve the 3 Blue Light status and failed. Over and over again. Then I remembered the DVDA1 trick with the 4310. After trying over and over it helps to reseat the Dlink cable. Not sure why that makes a difference (or if it is just luck) but for some reason it worked. Not sure why it is so hard to make it work. Maybe a firmware could help? Either way with or without the third Blue light the sound is awesome in my theater. If it is not happening for you I suggest not to worry about it and just enjoy the movie.
post #300 of 1124
DreamCatcher
You still need to have follwed the instructions on p.88 of the AVR manual, but even having done that, I couldn't get any joy the first time, hence the post.
Also, I've found that the power-on order is important, Screen then AVR then DBP. Its a bit of a pain because unlike the AVR the DBP doesn't have a hard power switch. As I'm doing my small bit to be enviro-concious (well as much as an AV-head can be that is ), it means the I have to use the mains switch on the outlet, so the DBP goes straight into standby whereas the AVR doesn't. Daft that the DBP doesn't have a front panel mains switch as well.
