^Some options:
First make sure the discs are clean. I use dilute mild dishsoap and inspect the disc with oblique lighting.
Next: compressed air, see this post.
Next: clean the laser lens with a BluRay laser lens cleaning disc as a dirty lens is a likely cause of no-disc error.
Next: Turn the device off and unplug it. As it's OOW, take off the outer casing. This will allow you to see if anything is simply stuck or jammed. Nudge at own risk. While you're there, properly clean the lens while the player is open. The lens should be cleaned with isopropyl alcohol and a cotton swab. If no joy, take your player in for service but I'd not buy an expensive HDMI board without a very good explanation as to why.
