Hi all,
I received my ps3 slim today. I was all prepared with my monoprice HDMI 1.3 Cat 2 certified cables to plug into my reasonably new RX-V3900.
So I plug the PS3 into the V3900 via HDMI and I get video up on my Samsung PN58B650, but no audio through the speakers.
In the 3900 menus I switch the HDMI audio through to the TV and I get audio from the TV speakers. Switch it back to AMP and I get nothing.
The indicators on the 3900 show PCM and LCRSLSR all active.
I see in the 3900 manual that it says (on pg 17) that HDMI supports DSD, DTHD, DDP, DTS-HDMA... No mention of PCM.
However since the manual recommends that HDMI is the preferred connection for all devices that have it, I am guessing PCM must be supported.
I tried setting the audio output to bit stream on ps3 and got no output either.
I have the same issue with my UVerse VIP 1200 box, but with that box I do not get the decoder indicator or the input speaker indicators so I can deal with that (TOSLINK cable) - people have indicated that these boxes have issues with audio over HDMI (though it seems to pass through ok).
I can hook up a TOSLINK cable to the ps3, but I would rather not since it does not seem like I should have to and it does not support the high res bitstreams (right?).
Am I missing something obvious here? I have the latest firmware on it 1008 - I think. Please help I am at my wits end here.
One more slightly off topic question - I have a Mac Mini and could not get it to output 1080p DVI - HDMI through the 3900. I could only get 720p. Any one have a setup like this working?
Kevin
Kevin
