Originally Posted by michanecash
so i am guessing that Blend refers to multiple CRT PJs blended together into one picture?
Well maybe you guys can help me plan this out. I wont be able to realistically complete this until later this fall or even after xmas, but I want to start planning it out.
I have read through most of Curt Palmes website. I think I have a pretty basic understanding of the technology.
My budget will be under $1000. Any suggestions on what I should get?
Get a Barco. Everybody likes Marquees, but Barcos are just as good or better, and Marquees are just too damn ugly to have visible in your house. If you're planning on building a hushbox to go around it, you could probably get away with a Marquee, though.
I think Barco setup is somewhat easier - apparently with Marquees you have to worry a lot about not using too much point convergence, or you end up with these wacky lines across the screen, geometry has to be perfect... My Barco 808 seems to handle pretty much anything.
Whatever you get, find a way to have color filtered (not corrected - FILTERED) lenses, c-elements, or glycol. It is *ESSENTIAL* to having a good picture. Absolutely essential. If I had to make some kind of agreement with God to not have color filtering on my Barco 808s, I'd strongly consider swapping back to a 1271, which is an order of magnitude lower on the performance spectrum otherwise; that's how important it is.
For that budget, I'd really try to find something liquid coupled, though I don't know if you could get a 9" LC for that unless you were pretty lucky. A Sony G70 would probably be good, though people are saying they're getting hard to find parts for. But a G70 is probably the max performance you could find in that price range. Another option in the same performance range would be a Zenith Pro 1200x/Barco Cine8 Onyx - but I think those are fairly hard to find?
what started out as one marquee 8000 turned into 6 marquee's.
And i still find myself looking for more!!!!
