AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › *Unofficial* Mitsubishi HC3800 Thread
*Unofficial* Mitsubishi HC3800 Thread - Page 11
post #301 of 6330
Offset is constant to image height (or diagonal). I think, if you change distance and zoom with constant diagonal, offset remain the same.
If the distance is constant (given for PJ which is mounted), changing zoom provide to change of offset (with change of diagonal)...
post #302 of 6330
Originally Posted by DooLocsta View Post
I would absolutely love to look into the W20000 but I am afraid it is in the stratosphere when I am talking about my budget
Check the Benq store often. I've seen refurbed W20000's show up in there for about $1600 (about 3 months ago). Yes it's a refurb, but its BenQ selling them, with a warranty.
I (like you) would have bought it in 1/2 a heartbeat, but alas, the zero offset (practically 0) won't work for Me . I'm just as upset about this as people who can't use a PJ they want due to Too much offset.
I don't check their store anymore, 'cause of course I can't make the W20000 work for me...
post #303 of 6330
bsampson -- No, the HC3800 offset is relative to the bottom (or top, if ceiling mounting) of the screen.
Only those PJs, that have lens shift, refer to "0" offset as being relative to the screen center.
wiatrak -- Your second paragraph is confusing the issue. If you zoom the PJ, you are, effectively, changing the screed size. The offset is based on screen size only (a percentage of the screen height). It is assumed that the owner will zoom the image to fill the screen height (for a 16:9 image or 4:3 image, only).
post #304 of 6330
Claus,
So does the distance between the bottom or the screen (or top in ceiling mount) and the center of the lens remain constant when zooming in or out?
post #305 of 6330
Originally Posted by bsampson View Post
Claus,
I think I know what you are trying to ask.
You're asking if the offset (in %) is different for the same screen size, but the projector at different zooms. So say 100" diagonal = 87" x49"H.
34% of 49" High = 16.66" offset.
This will be the offset regardless if you mount the projector 10ft from the screen and zoom to 100" dia or mount 15ft from the screen and zoom to 100" dia. The offset will be 16.66" (assuming it's actually 34%) either way.
post #306 of 6330
While we are waiting for the first units to ship, here is some marketing information on the HC3800. It helps understand what the design brief was.
http://www.projektoren-datenbank.com...ihc3800-en.pdf
I also note that the European model seem to be dual voltage, whereas the North American spec sheets only talk about 110V (which may be wrong)
post #307 of 6330
I wonder why the brochure says "Convenient Power zoom/focus and lens shift" when we all know it doesn't have lens shift.
post #308 of 6330
The brochure says also: "0.74" 3-DLP® (with Micro Lens)".
I think it is copy/paste bug from new LCD PJ specs...
post #309 of 6330
Originally Posted by DaGamePimp View Post
Has anyone been able to confirm that Best Buy will be carrying this model, they have the 6800 in stock already so I am hopeful that the 3800 will also be a stocking item due to the entry level price. Just hoping to see one in action .
Jason
I asked a guy in Magnolia today... he said that BB would not be carrying the 3800 Between that, the pricing of the Optoma HD20 at $1099, and the general lack of knowledge about projectors with their staff (I had to talk to two guys before I got someone who knew what I was talking about) I wonder why BB is even in the projector market.
post #310 of 6330
Claus,
Yes. The image remains centered on the screen.
wiatrak -- The only difference between your quote and the one in the brochure for my HC5500, is the replacement of "LCD" by "DLP". AFIK, there are no 0.74" DLP chips (their closest one is 0.7"). Your conclusion that it is a "copy/paste" error is correct, IMHO.
laeriq -- Because they can make a lot of money/PJ for the ones they do sell (more than they do for flat panel TVs, since they have local competition for those). Also, warehouse costs are a lot lower, so they have a higher profit margin. Their only competition are other BB store managers who chose to lower prices to move more product.
post #311 of 6330
That's assuming they sell them... at least in the two stores I frequent I don't see many moving. I see lots on clearance... in fact the one I was at today the HD20 was the only non-Magnolia projector they didn't have on clearance. They had the Optoma HD71, Epson 6100, and Sony something or other (older 720P). I just think that if they carried items like the HC3800 and actually promoted them like they do flat panels that they would enjoy all the advantages you describe. I know for one that I would take a hit on sales tax just to buy a HC3800 as soon as it the store.
post #312 of 6330
...is the replacement of "LCD" by "DLP". AFIK, there are no 0.74" DLP chips (their closest one is 0.7")...
Also "Micro Lens" (Array) is describe of LCD panels... Next one typo.
In other place of this brochure, it is corectly written: "0.65" 1-Chip DMD, DDP3021".
post #313 of 6330
Bummer, but figured as much due to lower profit margin .
Thanks for the info .
Jason
post #314 of 6330
Originally Posted by Legairre View Post
4805's offset was 27%
Bummer. That seemed to be the ideal offset for my room. I'll have to see what the final spec is, but it probably is that 35% someone mentioned on the xx1000.
post #315 of 6330
Jason
Best Buy will not carry any fp that does not have lens shift.They had so many problems with the old Mit 3000 that they learn their lesson.To many people return them because they could not get it to work in their room.Got this info from a store manager.
post #316 of 6330
They carry several without lens shift including the Optoma HD65.
I wouldn't put much faith in the word of store managers...
post #317 of 6330
Hey guys I always see Art's reviews use the term "best mode". What exactly does he mean by best mode? When in best mode what settings is he using, high lamp, gammas, etc...
Legairre
post #318 of 6330
Legairre
By "Best" Art means the settings that provide the Best Cinematic image.
On many projectors this is also the dimmest image as it the settings that give you the greatest contrast and best blacks.
However, on the HC3800 this "Best" setting also provides very high lumen output... not maximum, but much higher than on most projectors.
Art will list in the calibration section of the review the settings he used to obtain this... however as every projector and bulb are different those settings will Most Likely not be the same as what we would need with a different projector..., but for many they provide a good "starting point" from which you can try and calibrate your projector for your room conditions, screen, and bulb.
As the projector Art was using was just an "engineering sample" he may not have posted the settings used yet... he will probably wait until he gets an actual "production" model to publish those settings.
post #319 of 6330
The only thing I don't like about Art's reviews is that he normally has the projector's bulb set to high power.
post #320 of 6330
I seem to remember he tests them both ways.
post #321 of 6330
Thanks Steve that explains a lot.
post #322 of 6330
I wish it was more clear when he was in high and when he was in eco-mode.
post #323 of 6330
I agree. And because of the confusion, you don't know if you can use his settings. Are you listening ART?
post #324 of 6330
Hey guys I found the throw distance calculator for the HC3800. Just click the link under the pic of the projector. http://global.mitsubishielectric.com..._features.html
post #325 of 6330
Legairre & Jim McC -- Art is very specific about how he does his reviews. All of the calibrations are done in the "high" lamp mode. He also includes the effect of using the "low" lamp mode, as well as the effect of using the zoom. Complaining about common details (of the "cut & paste" variety) is being totally unfair to Art. After all, he is the only person doing the large number of PJ reviews that he posts. Only recently has he gotten calibration support from Mike (http://www.surfremotecontrol.com/). Remember, that each PJ may need a different set of calibration settings for your setup -- they vary from unit to unit and depend on your screen and viewing conditions. Reading more than one or two reviews of Art's will make this information very clear (he tries to be very consistent, so the reader can make the needed comparisons). He also specifically states that his "screen shots" are intended to support his text, and not the other way around (ie, comparison of relative PJ performance).
If it sounds like I'm a "fanboy" of Art, I am. I have been reading his reviews for the last 5+ years, and I'm very familiar with them. His reviews are very through and contain sufficient detail for me to make an intelligent purchase. This is contrary to the one page "summary" type reviews that are published by Evan Powell and his staff at PJC (and some of their recent ones seem to have included more errors than usual).
For the most part, switching from "high" lamp to "low" lamp power will not effect the calibration settings significantly. It didn't for my current 1080p PJ. This is also why Art states that each owner should do his own calibration, YMMV. In his newer reviews he does state that his calibration settings could be used as a ""starting point", but is not a substitute for doing your own calibration.
post #326 of 6330
CT with all due respect I've read many of his reviews and it's not always clear when he's in high and when he's in eco mode. Some reviews it's very clear and others it's not. I also don't ever remember complaining about any cut and pasting. I asked a simple question, got an answer from Steve and replied that I wished it was more clear which mode he was in. Nothing more, nothing less.
post #327 of 6330
With that calculator, it seems like ceiling mounting is a no go with ceiling 8 ft. and under. I tried getting at least a 120 in. diagonal screen that is about 3 feet off the ground and it just wasn't going to work. The largest screen I got to fit was 80 in. which seems quite disappointing for a projector..
post #328 of 6330
Grimm, You can get a 120" with a 8' ceiling, but you'll have to tilt the HC3800 up a bit. My current projector(HC1500) has a 35% offset (34% for the HC3800) and with the slight tilting the viewable area of the screen is 19" off the floor with no bowing of the image.
According to the HC3800 calculator the image will be 5" higher due to the 1% difference in offset from my current projector which would put the image 24" off the floor and I have a 7'4" ceiling in my basement.
With an 8' ceiling and slight tilting of the projector you should be able to get a 108" image at about 30" off the floor. Bump it up to 120" and your probably at around 20" off the floor like my 108" screen.
If you look at the pic 20" off isn't that bad. I know it's not the 36" you want but it is do-able.
post #329 of 6330
Are you using the keystone feature to straighten the image out?
post #330 of 6330
No keystone at all. Myself and several others with the Mitsubishi HC1500, HC1600 and HD1000U, tilt the projector without any keystoning. You can tilt a certain amount before getting the trapezoid effect. I've noticed I can tilt enough to raise the screen about 5 inches, after that I get the bowing /trapezoid effect.
