Originally Posted by golffnutt
Hey Guys quick question. I am getting ready to pull the plug and buy one of these projectors but before I do I need to know if it will fit my room and screen.
My screen is 10' wide (120 inches), 16.9 aspect ratio, this is actual width not diagonal measurement. The distance from screen to where projector (the lens) will be mounted is 16.3'. This is absolutely as far back as it can be mounted, will I get my 12' screen at this distance? Will this projector work for these measurements. I know there are projector calculators out there but dumb me has trouble understanding them so your help on this will be greatly appreciated. Thank you so much and have a pleasant evening.
It will work for the size, BUT it will be too dim, only 10 foot lamberts.
