Originally Posted by
golffnutt
I see the "i" when watching Directv, 1080i, I just never see the P when watching a BD.
Also how do I check to see if I am receiving a 24p signal?
Just to note (if you didn't already know), ALL projectors display progressively. Same for flat panels. If you feed 'em interlaced, they
have to convert that to progressive to display it (they're progressive displays). 1080i still has less information than 1080p (quite a bit less), but when you see a projector flash 1080i or 1080p (or just 1080), it's just an indication of the input signal, not the projected image.
So, just make sure your Oppo is set to output 1080p all the time (so that even dvd's output 1080p----the Oppo's conversion is top notch), and you're good to go.
