Originally Posted by stash64
For the home user like me, I don't want to spend hours trying to sort through the interface. I want to spend that time on the actual calibration. If its software you use only a few times a year, I think it is important that it be very intuitive and user-friendly... and I guess that is the main reason I like the looks of Tom's solution. Colman may be more powerful and customizable but I think most home user's will find Tom's easy-to-navigate interface a real advantage.
Stash64 has nailed the ChromaPure vs. most other calibration software comparison in just about every respect. ChromaPure = simplicity with calibration completeness including CMS. Maybe you can't use ChromaPure to measure gamma or other measures 20 different ways but who wants to.
I have just received my copy of ChromaPure and it simply can do everything I want or need to easily and completely do an accurate run.
FWIW I am a beta ColorFacts user to Ver. 7.0 and also own CalMan Pro.
My opinion is
from beginner to long time pro ChromaPure is now at the top of my list for calibration software whether it is expensive or free
) to get familiar with it. I really like the way you can adjust the gamma in real time, which is a current issue with my HD350 as it has 'flattened' to an average of 2.0.
). I was happy with the results and found it much easier to dial in the gamma to follow 2.2 using the real time display while I adjusted each point using the HDQ's luma controls. Also the real time colour gamut measurements made finding the 'sweet spot' compromise quicker than I'd ever manage with my previous free software.
