AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Free KuroReader Software for Pioneer KRP-500M, KRP-600M, PRO-101FD, PRO-141FD
Free KuroReader Software for Pioneer KRP-500M, KRP-600M, PRO-101FD, PRO-141FD - Page 3
post #61 of 107
Originally Posted by zoro View Post
do we need isf patch for pro 151s too?
No, it's only required to enable ISF for US KRP-M's.
post #62 of 107
Originally Posted by bakker_be View Post
Will this work for my PDP-LX5090H too?
thnx,
Bart
No. KuroReader requires Pioneer's IP Control Interface and the 5090H only has the RS232 interface.
post #63 of 107
Can't wait to try this out. Is this app strictly a reader as the name implies, or can you change settings on the tv using this? Just want to make sure so that I don't do anything dumb like overwrite my isf settings.
post #64 of 107
The Reader and Service Info tabs will only read data from the display. The other tabs connect to the Kuro's built-in Web Control Interface and do allow changes to settings. Some of these are shown in the User manual starting on page 69. These web pages can be accessed using Internet Explorer, but I placed them in KuroReader for convenience and to control (and hopefully improve) some of the interface's annoying behavior in the browser.
post #65 of 107
Great!!! Thank you.
post #66 of 107
jbimmer,
I'm getting my panel today and for now would like to "open up" the ISF modes for the brighter picture.
I'm not very good at networking, etc but do have a network cable in the living room for my Egreat NMT player. (From wireless/wired router in office)
If I plug it in to the 101, will it show up on the network (My network places)?
Can I access it from a laptop that is connected to my wireless network?
Appreciate any guidance for an older guy here
thx
bob
post #67 of 107
First you need to enable IP Control in the Control Setup menu on the 101 (Page 64/Sec 6.8.1 in the 101FD user manual). Most likely your network uses DHCP, so you would also set the 101's DHCP "On" - the setting is right below the IP Control setting in Control Setup menu. The rest of the items on that screen should be left at their defaults when using DHCP.
Yes.
post #68 of 107
Yes.
Will try after break in.
bob
post #69 of 107
Maybe I'm stupid, but after setting the ISF modes, and seeing them listed as "yes" for my chosen input, I still can't access them. Or perhaps ControlCal is still required to fully access these modes?
post #70 of 107
Turn the Kuro off and back on and see if they are there. If not, try creating ISF day first.
post #71 of 107
Did so, no joy. Any other suggestions?
It's a cool program nonetheless. Well done!
post #72 of 107
Other 101/141 owners have reported success, so you may just be missing a step or the running into some of the display's quirks. First, make sure the display is receiving a video signal on the input when you adjust and save the ISFccc mode. Also, make sure you press the Save button and then the Exit button after making your adjustments, then power off/on.
I ran into a similar issue trying to enable ISF Night on my 500M during testing - I ended up getting either ISF Auto or Day activated first and then was able to activate ISF Night. I am not sure exactly what got it working other than persistance.
If you don't make any progress, you may want to consider purchasing ControlCal which has the benefit of additional picture controls (those you can see in the Pro Adjust menu in non-ISF mode) for a reasonable price.
post #73 of 107
If you don't make any progress, you may want to consider purchasing ControlCal which has the benefit of addition picture controls for a reasonable price.
We can't change picture settings w/ KuroReader? I thought everything but gamma??
bob
post #74 of 107
bob
You can access the built-in Pioneer ISF settings page* with KuroReader or Internet Explorer (by bypassing the password page) to adjust the following picture controls:
Contrast
Brightness
Color
Tint
Sharpness
Color Temp: (Low, Mid Low, Mid, Mid Hi, Hi, Manual)
Color Temp Manual:
Red High
Green High
Blue High
Red Low
Green Low
Blue Low
You can't access additional ISFccc mode settings:
ISF RGB Point Gamma 1-9
Film Mode
Text Optimization
Intelligent Mode
DRE Picture
Black Level
ACL
Enhancer Mode
CTI
Color Management
R (RED)
Y (YELLOW)
G (GREEN)
C (CYAN)
B (BLUE)
M (MAGENTA)
Color Space
3DNR
Field NR
Block NR
Mosquito NR
3DYC
IP Mode
Zoom (default)
Most importantly is the lack of a Color Space control in the Pioneer ISF page since I believe it defaults to 1, and CS2 is the preferred (accurate) mode. All of the Picture controls listed above are available in ControlCal.
*I didn't write the page, Pioneer did, I just made it work better
post #75 of 107
Thanks, JD
Started break in at 4:00 PM today (PRO-101)
bob
post #76 of 107
I'm off to Fry's to get a 25' network cable to try KuroReader into my router?
Does it matter what type? Crossover, etc?
thx
bob
post #77 of 107
thx
bob
You need a standard ethernet cable to connect the 101FD to your router. The crossover ethernet cables are required only for direct PC-Kuro ethernet connections, if the PC does not support Auto-Xover.
post #78 of 107
Off I go!
bob
post #79 of 107
OK,JD
It's plugged in to the router.
Should it show up in Network Places (Vista 32)?
IP Control is enabled
DHCP is On.
Been about 5 minutes and nothing.
Reboot PC?
update: Even tho the Kuro never showed up in network places, I was able to access it w/ the laptop and actually activate ISF DAY and save a few settings. I changed DVD's (not inputs) and now I can't get back in:
http://www.flickr.com/photos/2428129...84192/sizes/o/
My Kuro's IP is 192.168.001.001 which I entered into the Kuro IP address but now it's a no go.
thx
bob
post #80 of 107
No, it won't show up there.
post #81 of 107
192.168.001.001 sounds like your router's (typical) IP Address, are you sure that's right?
Although I haven't seen it occur using KuroReader, sometimes the Kuro's network stack hangs. To resolve, turn off the main power switch in the Pioneer (the big one on the lower left underside when facing the display), wait about 20 seconds and turn it back on.
post #82 of 107
BTW, if you are not sure what the Pioneer's IP Address is when using DHCP, it should appear in the Control menu.
post #83 of 107
JD,
I checked again and the Kuro IP is that with or without the cable plugged in.
Control setup/ IP address.
I'll try the power switch, too
thx
bob
post #84 of 107
It doesn't appear until I click IP address. Then it brings up a small data window.
bob
post #85 of 107
That's correct. The IP address, subnet mask, default gateway and mac address are displayed when you select them.
post #86 of 107
OK,
BTW,my router is 192.168.1.1
The network cable is temporarily being used to check out my netwrk media player while I'm breaking in th 101 in a spare bedroom.
bob
post #87 of 107
OK,
bob
Ok. Just to be clear, 192.168.1.1 is the same as 192.168.001.001, just different notation.
post #88 of 107
I did not know that
So, am I looking in the wrong place?
What should the Kuro IP be, then?
thx
bob
post #89 of 107
I did not know that
No, I think you are looking at the only place it shows the IP.
Once you hook it back up to the cable, go back and check it in the Control menu again by selecting IP Address. There are some home routers that use a different default than 1 in the last octet (xxx.xxx.xxx.1), so it's certainly possible that yours is configured differently and 192.168.1.1 is available in the DHCP pool. And you were able to connect to it and create ISF Day before, so maybe you just need to verify it again.
post #90 of 107
Will do but I can assure you that192.168.1.1 is the only way I have ever got to the router menu, etc.
Also, when I run ipconfig it always shows up as the default gateway.
bob
