AVS › AVS Forum › Video Components › Home Theater Computers › New heatpipe and fanless HTPC case designs
post #1 of 132
http://www.missingremote.com/index.p...=4034&Itemid=1
Is the story
www.hd-plex.com is the site
What do you guys think?
post #2 of 132
Well, it's not the most attractive case, but it's a great idea. Certainly this would be ample cooling for low-mid range HTPC builds.
post #3 of 132
I believe an avs member was the one behind this case, I'll see if I can't dig up the thread.
post #4 of 132
Not many choices out there so everybody welcome.
Would never buy the side-mounted BR drive, MUST be center mounted and am unanimous on that, and no external PSU variety either.
post #5 of 132
Not bad.
Would be great if someone came up with a good way to mount the heatpipes though.
Got a HFX chassi myself and you really really really don't want to remount stuff or change gfx card etc.
post #6 of 132
There are few heatsink cases in the market already in last couple of years. The first thing I personally want for HTPC nowadays are nothing but bitstream feature. But with today technology, we need a Xonar HDAV or Azuentech HD full height PCI-E or PCI card. With that said, this particular case won't do it for an obvious reason. About a year ago, I look at a full height heatsickcase, I think it is in UK or Germany but it costs about $1,400 with all the CPU and HD heatsink attachments, a bit too much IMO.
post #7 of 132
The look is reminiscent of a Harmon Kardon HK770 amplifier I picked up on Ebay a few years ago...
post #8 of 132
They don't list the detailed specifications. What is the maximum ambient room temperature allowed? I wouldn't pay any attention to it until they provide some more information.
post #9 of 132
You're probably thinking of HFX, http://www.hfx.at/
post #10 of 132
H10.ODD/H5.VFD/H5.S could accommodate full height PCI-E card with riser. As for the price, it should be no where near 1/4 of that number with PSU included.
My own test showing E8500 at around 60C with 30C room temp. Of course, I am biased. Please wait for the SPCR review.
post #11 of 132
Right on. That's the one.
post #12 of 132
Oh I missed the riser part. Yes, with riser card, it looks like it will clear and some full PCI-E card(s). How many of the PCI-E it will allow in H10.ODD/H5.VFD/H5.S with riser card(s)?
post #13 of 132
One.
post #14 of 132
One.
Are they all mATX/mini-ATX only? no ATX?
post #15 of 132
H10 series could accomdate ATX but I really don't see a reason for going ATX for this low profile H series since they allow only one extra card with riser.
post #16 of 132
Here is my hardware. It is by far the quietest HTPC i have built inculding a water cooled (zalman Res Tower).
Hardware
Case: NmediaPC HTPC 2000B
CPU: AMD Phenom II x4 940 Deneb 3GHZ Quad Core
Motherboard: Gigabyte MA790GP-UD4H 790GX chipset
Memory: OCZ Reaper 4GB DDR2 1066 mhz
Hard Drive: Western Digital 1TB Green HDD
Drive: LG HD-DVD/Blue ray
PSU: Corsair 520HX 520 watt
Cooling Fans:
CPU- Artctic Cooling Freezer 64 Pro (93mm fan, MB controlled)
Case- Antec 120mm 3 speed fan (set on low, side vent)
PSU- 120mm Thermally Controlled
From one step away you can not hear the HTPC at all in a dead quiet room.
The WD Geen HDD are the low rpm type and are very quiet and i'm using onboard video/Audio output Via the ATI 790G chipset HDMI. Streams my BR ISO's flawlessly.
System runs very cool in that NmediaPC case and the CPU and PSU fans seem to stay on lowest rpm settings all the time.
I have tried dynomatt and other things but after not hearing this HTPC I think most people can create an almost silent HTPC. Case and components are key.
post #17 of 132
I hope they can beat A-Tech Fabrication's prices! I might jump on these, they look great!
post #18 of 132
sexy hardware, comes down to price.
post #19 of 132
Isn't there a Asus Xonar half height card now too?
post #20 of 132
They've 2 versions, regular and Slim, but both of them are full height.
post #21 of 132
um, the slim is slim (half-height).
Although the slim is also PCI (not the express varient).
http://www.newegg.com/Product/ShowIm...s%20-%20Retail
post #22 of 132
I must be crazy tonight especially I've on inside the case sorry Slim is 1/2 height.
post #23 of 132
Promising looking cases, thanks for the link.
post #24 of 132
The price should be in line with mainstream HTPC chassis.
post #25 of 132
They are not.
post #26 of 132
Originally Posted by MrBobb View Post
They are not.
No kidding - A-tech's expensive. I think he meant the price would be in line with OTHER mainstream chassis, not in line with A-tech...
post #27 of 132
Am surprised the Chinese are not jumping into this. I mean they are just hunk of aluminum, and yet charge 2x - 4x as much!
post #28 of 132
In their defense, I used to work for BOXX and they designed and fab'd their chassis here in the States. It is very expensive if you're not outsourcing overseas...
post #29 of 132
Why? Just two slaps of heatsink (comercially available, ready-made). flat top/bottom covers, drilled/stamped rear, and maybe a fancier (another $20?) front cover. Heatpipes, if provided, are commercial, ready-made correct?
I mean there is any hardly anything custom about them, as in hand-made.
post #30 of 132
I have a really nice setupo using a HFX classic case. It almost noizeless for typical operation having just one fan in my power supply running at less than 500 rpm.
The main issues with tehse setup is the noise generated by the bloody blu-ray drive (lg Blu-ray writer). The HFX classic doesn't provide any mechanism to reduce that noize. For listening music on a server (using foobar) this is great. for blu-ray back I have to suffer drive noise.
I look at the HDPLEX FAnless and it will suffer the same lack of isolation drive noise insolation.
The drive noise is sad considering that the second noisiest component is the HDD which will be resolved in a year or 2 with the advent of totally silent SDD drives.
Only the HFX Mini provide such some sort of isolation but it limit the drive choice to slot drive instead of tray.
