Does anyone have any issues with these? I ordered the "solder-free" type of banana plugs and 1/3rd of the ends came off after installation. Seems kind of weak (I followed the instructions in the pdf). Are there any other tips to make a more secure fitting of banana plugs on the speaker wire? I guess I'll have to solder them in.
Also, I was wondering if it's normal for gold-plated RCA cables to have very loose connections to the socket on the back of the pre-amp to the inputs on my Emotiva. My brand-new Emotiva complained there was a short on one of the inputs for a split second as I pushed the amp back into the rack...when I investigated I found it had fallen out and made a bad contact! Bad on you, Monoprice. Why are these fittings so loose? Am I supposed to crimp them tightly with pliars so they don't fall off? my old RCA crap cables were better than this. I nearly lost an 800 dollar investment!
wondering ig anyone else went thru the same things. right now feeling a little silly having ordered all this stuff. The backs of my Klipsch THX Ultra2 KL-650s handle the banana plug inputs, but doing so makes the brackets looser and tend to come out. Come on! I think I was better off with just twisting the wire in like I've always done.
//rant over
//rant over
