Looks like there is a new entry level remote from Harmony, the 700.
From the Harmony blog,
At Harmony, we're pretty passionate about creating fantastic control experiences for all sorts of entertainment systems. Announced today, the Logitech Harmony 700 Remote gives people the power to control home-theater systems with up to six devices in a stylish package that's easy enough for the entire family to use.
Over the last few years, we've really focused on the details that make a remote enjoyable to use. For the Harmony 700, we included hard buttons for the activities you use most often, a color LCD screen for easy browsing of your favorite channel icons, texture and paint finishes that feel great and resist fingerprints and perfectly shaped, back-lit, soft-touch buttons.
But Harmony 700 isn't just beautiful, it's brainy too. One of the most interesting features of the Harmony 700 is the way it can help you recover from incorrect delay settings. IR delays are pretty complicated stuff, and when they're not set correctly you might experience a device not turning on or an input not being switched correctly when starting an activity such as Watch TV. Now, with Harmony 700, if you use the on-remote Help button repeatedly to solve the same delay-related problem, the remote will recognize that and prompt you to fix the setting right on the remote.
And to make sure the Harmony 700 is always ready to entertain, it's rechargeable. In fact, the same USB cable that you use to program the remote connects to an AC adaptor that plugs into the wall. So whether you want to recharge your remote, or reprogram it, the cable is always handy.
From Engadget,
If Logitech's multifaceted Harmony 900 seemed a bit too rich for your blood, why not give the whole universal remote thing another chance with the Harmony 700? Priced at $149.99, this entry-level clicker packs an awful lot of promise into a package that practically any serious home theater junkie will be able to finance. Designed to replace a half-dozen remotes in your current setup, the 700 features a color display, rechargeable AA batteries and one-click control of your favorite activities. As with every other new Harmony, this one too can be connected to your Mac or PC and programmed via the internet to control whatever components you rely on -- "from Betamax to Blu-ray" as Logitech so eloquently puts it. Details beyond that are few and far between, but we're guessing the outfit's keeping things as simple as possible here as to not befuddle the target market.
At a $150 MSRP I'm guessing this will go for less than $100 on Amazon.
From Gizmodo,
The $150 Logitech Harmony 700 is much like their other non-touchscreen universal remotes in that you have a load of physical buttons to push. However, the 700 is difference since it gives you four physically labeled activity keys.
When using Logitech remotes, the point is to let the remote know every single appliance in your setup so you can focus on "activities", such as watching TV, or playing your Xbox, or watching a Blu-ray on your PS3. That way your remote knows exactly which thing needs to be onand which boxes don'tfor what you want to do. Since these activities are now tied to a separate physical button, you can just hit that button instead of scrolling through a list in order to get where you're going. It saves a few seconds each time, but adds up over years of TV watching.
Other features on the 700 include a color LCD screen, rechargeable AAs and compatibility with the standard Logitech remote setup program. It will be available in September.
From Engadget,
From Gizmodo,
