Originally Posted by
jake9
But after reading the above posts it seems many DVRs don't have the "discrete" thing which controls this.
The word discrete, as used here, means there a device accepts one IR command for
turn power on and a different (or separate or independent) command for
turn power off, rather than, or in addition to, a single
power on/off toggle. My TV accepts all three but I only use the discrete commands on the Harmony 700.
jake9
If hitting the Activities button twice will work to get back to the activity then I will try that. Thanks.
The first press takes the remote back to the Devices screen. The second press toggles from the Devices screen to the Activities screen where, if you were previously in an Activity, you're put right back in that activity.
The remote doesn't have discrete commands (i.e., buttons) for controlling itself like this!
