Originally Posted by
mdavej
This is normal. The 700 is 6 device with the stand-alone software, or 8 device on myharmony.com. But using myharmony.com will cost you the loss of sequences, the ability to add more than 5 activities, the ability to adjust your backlight time and delays and repeats, and the ability to rearrange activities. Pick your poison.
Interesting.
I have 6 devices(5 already hooked up and 1 pending), so I will not go the 8 devices route right now. I like the flexibility of moving things around right now, and wouldn't like the more restrictive menu set up going with 8 devices should I need to add more. I will prob go with a remote upgrade, which I guess is exactly what Harmony would want. But for now, the 700 suits my needs perfectly.
One other question. How do I do a firware upgrade in safe mode? I managed to get the remote into safe mode, but, on the MyHarmony site, I can't find the download tab? The help section states that it is in the top right hand corner, but on my window, it isn't there.
