AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The best way to hook up my iphone 3G to Marantz SR8002 Receiver?
post #1 of 5
I recently purchased a Marantz SR8002 receiver and B&W MT-30 speakers which I am hoping to hook up in the next few weeks. I want to know if anyone has recommendations on the cable/s I should use to get the best sound from my iphone 3G to speakers through my receiver. It would be a bonus if I could watch video on my tv as well. My last HT was an onkyo HTIB 990THX and I used a monster AV cable which sounded okay however, I was wondering if there are other options e.g. HDMI or USB with a docking station. Please let me know. Thank you.
post #2 of 5
This isn't exactly what you are asking about, but you might prefer this. The iPhone can control iTunes on your home computer wirelessly. So, if your computer is now hooked up to your receiver, all you need is to download the free iPhone app Remote. Then, your phone displays all the music in your computer's itunes and lets you play them out your computer, to your receiver. That usually gives you a larger library of music than would fit in your iPhone, plus your phone is not shackled to your receiver - its in your hand in your easy chair. You can control the playback volume and everything.
post #3 of 5
Since your Marantz SR8002 does not have a USB input you will probably have to go with using a PC or a docking station to send a digital signal to your receiver.
post #4 of 5
This is how I have connected my 4G iPod Nano (same connection as in iphone 3G) without any complex network, media server setup and the music can be controlled by Harmony or the remote which came with the dock. Total cost.. approx $15. Get this and connect the audio/video via traditional RCA audio/video jack to your receiver. The dock is capable of charging iPod or iPhone via the USB. Note than many older dock system are not able to charge iPhone or iPod Nano 4G (because they charge via the firewire port, which are not present in iPhone or iPod Nano 4G).
I bought something like this:
http://cgi.ebay.com/AV-Adapter-Dock-...d=p3286.c0.m14
Oh yes, you will be able watch videos too.
post #5 of 5
I recently purchased a Marantz SR8002 receiver and B&W MT-30 speakers which I am hoping to hook up in the next few weeks. I want to know the best way to connect my iphone 3G to play music and it would be a bonus if I could watch video on my tv as well. My last HT was an onkyo HTIB 990THX and I used a monster AV cable which sounded okay. According to the Marantz website, the receiver has "USB Audio" so I am guessing I can plug in the USB cable that came with my iphone. Can anyone that has the Marantz 8002 receiver confirm? Please let me know.
Thank you.
