The computer had a DVI to A/V adapter i think it was, so i connected the ps3 to it but couldnt get it working.. the pc didnt register any external device connected..
is there a way to connect it to the XPS ONE via hdmi or A/V?
thanks any help will be appreciated
EDIT:Sorry for the confusion, this is the adapter im trying to use:
http://support.dell.com/support/edoc...YU285am0MR.pdf
do you think it could work with the PS3 A/V cables? i tried but i think i forgot to change the ps3 resolution since i was using hdmi with my tv..
