AVS › AVS Forum › Video Components › Home Theater Computers › Movies with forced subtitles
Movies with forced subtitles - Page 5
post #121 of 556
Inglorious Basterds has forced subtitles for the French and German parts
post #122 of 556
Does it really? I ripped mine with NO subtitles and it seems to be burned right onto the movie.
post #123 of 556
I think the UK/EU version has them forced and the US version are burned...I could have that reversed though.
post #124 of 556
Yup...burned in to the US version...I just check the logs from when I ripped it.
Mike
post #125 of 556
If anyone would like permission to edit the list and keep it going PM me your e-mail address. I haven't been buying many movies lately so my rips have slowed considerably.
post #126 of 556
I've got the European version of the Bourne trilogy. I got a seperate forced sub track in Mike's program for Identity. Nothing came up as forced for Supremacy....
I can't remember, are there no non-english parts in Supremacy?
post #127 of 556
Guys,
I've just read this entire thread but I'm still having some trouble with the forced sub track in Kill Bill Vol 1.
I ripped the BD with Clown_BD and located the small forced sub track. I then converted this sub track in BDSup2Sub and put it in with my main title, audio, etc, in MKVMerge. I made sure that when I select that subtitle track in MKVMerge it has the "forced" flag set.
Yet, when I play the movie back in XBMC the forced subs don't show. Weirder yet, if I select to turn all subs on in the movie the forced sub track (and not the standard english subtitles) appears for those scenes.
Very confusing, what am I missing to get this to work with ClownBD, BDSup2Sub and MKVMerge?
post #128 of 556
What format did you convert the sub track to? I usually have the subtitles as a separate file (.srt usually) and PS3 Media Server can pick them up with a .dll file in the 'plugins' folder for AviSynth. You might have converted to the wrong format.
Originally Posted by jmpage2 View Post
Guys,
post #129 of 556
I worked on the Bourne Trilogy a few months ago as well and only Identity and Ultimatum had subs that were needed for english translation (forced subs).
post #130 of 556
You might have a player problem. I would use Media Info and verify the sub track is in the file.
Mike
post #131 of 556
The sub is in .idx/.sup format and muxxed into an .mkv with mkvmerge. I am playing them back on a PC with XBMC.
The sub track does show up in media info but does not indicate what properties the sub track has.
The sub track displays properly as forced in other media players, but in xbmc only displays if I specifically turn subtitles on.
post #132 of 556
Avatar has forced subs.
Mike
post #133 of 556
Mike
Yup, Track #9 for English. Just ripped without a problem
post #134 of 556
How do I merge this with an MKV? I have the SUP file but do I need to convert it to IDX? Will MPC-HC play it without a hitch? I heard it borks DVXA?
post #135 of 556
Check out my mkv guides here:
http://www.mediasmartserver.net/tag/mkv/
Mike Eby's Another EAC3To GUI will mux in the forced subs. I also have a writeup showing you how to do it manually using Clown_BD + BDSup2Sub + MKVMerge.
I am actually watching 2012 right now (has forced subs) in MPC HC, plays flawless (aside from the fact that it is a horrible movie). Let me know if you have any other questions
post #136 of 556
See next post...
post #137 of 556
OK... I'm trying to understand how to make a blu-ray to bd25 backup (no mkv) of a movie-only blu-ray with forced subtitles to play automatically. How can this be done? I am a newbie and I would appreciate a simple guide on how to do this. I currently am trying to work on Iron Man.
Thanks so much in advance for any insight.
post #138 of 556
hi all,
first, i'm new to the forum and i have joined up purely becuase of the excellent work being done here on this thread.
dealing with forced subtitles is a nightmare, so i thought i'd share with you my method.
1) backup private copy of my dvd (vobs and such)
2) run vobs through dvdsubedit,
3) check 'display forced subs' box
4) run through frames using slider to check the dialouge in question.
5) run the inbuilt ocr and save to .srt
6) combine srt with vobs when making the backup avi with autogk.
yesterday i bought a copy of district 9, and i'd forgotten the above method. i spent all day from 9 till 5 trying to figure it out. drove me totally insane.
then, after trawling the interweb and coming across this thread time and again for some reason my memory was jogged and hey presto, got a totally accurate forced subs srt in about 5 minutes flat with minimal brain use and minimal mouse clicking.
dvdsubedit rules.
and finally, a big big thank you for the list ! awesome effort !
post #139 of 556
More R1 DVD's w/ forced subs: Red Dawn, Charlie's Angels, Hellboy, Once Upon a Time in Mexico, Stigmata, xXx, Bad Boys II, Mona Lisa Smile, Boondock Saints II, Tomorrow Never Dies, Die Another Day. Might be useful when people add to the list to note what format/region they are talking about since a movie may or may not have forced subs if Blu/DVD.
post #140 of 556
The US Blu-ray of Youth in Revolt has some forced subs titles.
Mike
post #141 of 556
Mike
I show it is Track #5. Question Mike, when using your tool in command line mode and it demuxes all the files, does it do anything to separate the forced subtitles, or does it just demux all of the user defined subtitles (in my case English) and the user has to determine if forced subtitles are present
post #142 of 556
It "should" create a .IDX file that contains the forced subs. I just re-ripped (demux only) Defiance while working on the PGS project and there was a .SUB and a .IDX that was created by bdsup2sub.
Mike
post #143 of 556
Mike
Hmmm....maybe I have an old version of your porgram installed. I had ripped Youth In Revolt using the command line and the resulting files no forced subs were present. Will look at again.
post #144 of 556
That may have not worked in an older version.
Mike
post #145 of 556
Mike
Yeah, I just checked and every time I installed a new version of AEAC the old version stayed installed as well, so odds are I was running an old one. Just uninstalled all versions and reinstalled only the newest
post #146 of 556
Heres my addings of forced subtitle movies
Last Holiday
Transsiberian
Also season 2 of true blood has forced subs where eric is having flashbacks I forget what episode though.
post #147 of 556
please keep this thread alive!!!!!!!!!!
post #148 of 556
I've opened up the document, anyone can view/edit now.
https://spreadsheets.google.com/ccc?...4Z3FrYlE&hl=en
post #149 of 556
I just did
post #150 of 556
Yes I opened it up to allow you all better access to keep things up to date, however as soon as I did that last night someone deleted all of the movie names to be funny. So I'm not sure if it will remain open or not.
