Hi,
Thank you for the great thead guys, it is helping me significantly, but I am wondering how easy it is to check if a film needs forced subtitles? At the moment I just used makemkv and take all subtitles. The onmly way I know if I need to worry about forced subtitles at all is if I come here and look, or get half way through a film and find out that subtitles are missing.
Also does anyone have any hints for finding the correct time code for subtitles so I can check they are behaving correctly. Can I view the subtitle tracks within an mkv file easily (ie in notepad so I can see the time codes?)
As at the moment I rely on my memory of a film (which if I havent seen it for 10 years can be an issue
thanks in advance
