AVS › AVS Forum › Video Components › Home Theater Computers › Movies with forced subtitles
Movies with forced subtitles - Page 4
post #91 of 556
Originally Posted by MikeEby View Post
Agreed...Others have gotten forced subs in WMC working, I'll be damned how?
Mike
The problem isn't just getting subs in WMC, that can be done by forcing WMC to use the FFDSHOW Video Decoder (not the FFDSHOW DXVA Video Decoder); the problem is getting subs in WMC with DXVA. I don't think that can be done currently.
By the way, Mike, thanks for your EAC3to front end. Great tool! I'm using it even as I write this.
post #92 of 556
I stopped worrying about whether or not my ripped movies had forced subtitles a long time ago. I use Clown_BD to strip out the unwanted extras but I generally keep the English subtitles just to be on the safe side. They don't really take up much space and it's easy enough to turn them off if they're not needed. Since I tend to rip new releases as soon as they're out I'd be surprised if the database you guys are putting together would be of much help for my situation anyway.
post #93 of 556
Originally Posted by Killroyâ„¢ View Post
I don't use WMC for playback but it is usually the sub renderer that is the problem. With MPC-HC you either use the internal filter or an external one. Also have to allow the application to pre-load or auto load the sub while other filters do it on their own.
Whoa, i have no clue what you are talking about. I just figured after they were muxed in the subs would be burned into the movie file. So you are saying that i need an additional filter the view the subs with MPC-HC. How do you do this. Is this an option in MPC?
Then what do you mean pre-load or auto load the sub with an application? Is there a guide or instructions for this process?
Agreed...Others have gotten forced subs in WMC working, I'll be damned how? If someone has a step by step I would like to know how too. I've installed vobsub...what's the step after that?
Mike
I am sure someone out there is using WMC to play MKVs with subtitles.
post #94 of 556
MPC-HC has its own sub-filter if you use their video filters. In the Playback option menu there is a box that says "Auto-load subtitles" if you check this it will play the subs without doing anything on your part. You can use ffdhsow and vobsub (Ithink that is the combo) that can also do it but like others have said, it may break DXVA.
I use MPC-HC internal filters, EVR Custom renderer (it is mandatory for it to use the internal sub filter) and that is it. Easy Peasy Lemon Squeezy.
post #95 of 556
so if you go this route do you still need to mux in the sub file?
post #96 of 556
If you use .srt then you can leave them separate, but the same file name as the movie, if you use idx/sub then you have to mux them in. Someone thought that you could play them externally but for the life of me I cannot figure out how.
post #97 of 556
it seems all i needed to do was set "subtitle control" in the shark007 application to "DirectVobSub" now it works in WMC.... at least this file does.
post #98 of 556
My Life in Ruins has a few forced subs.
post #99 of 556
Any updates on this list?
Can anyone tell me exactly where in Iron Man the forced subtitles are shown? I see the chapters in the list but can't find them to see if my .mkv is working properly.
post #100 of 556
The scene in the cave after Tony gets captured, during the building of the rocket/first Iron Man, and the scene where the bad guys pull people out of truck and almost execute them and Iron Man first shows up.
I don't think there are any more but I may be wrong.
post #101 of 556
I just think the problem is my MakeMKV rip is not working because the subtitles are PGS files. MPC doesn't seem to recognize them. Anybody with ideas?
post #102 of 556
You have to use subrip to convert them to srt file then you can merge them to your mkv
post #103 of 556
Ok, so I downloaded MKVextract & chose my MKV file. Right away it says "MKExtract cannot extract this kind of file".
So what the hell? lol
post #104 of 556
Is this MKV includes Flac audio track?
If yes then this is normal. Beleive it or not, MKVmerge can create file with flac audio, and those file will play perfectly, but it can't process them afterward because they can not open file with flac audio because the mkv standard says that flac is supposed to be encapsulate in an ogg container in an mkv container!
IN short, it can create working files that it can't process afterward.
post #105 of 556
This happens when I select which PGS subtitles i want to work with.
post #106 of 556
I've read through this thread and I'm pretty
I'm in the process of ripping my entire DVD collection to my htpc - mostly standard DVDs, just a few BDs. I'm using DVDShrink on the DVDs to rip just the main movie, main soundtrack and English subtitles. I'm doing the same thing for BD using ClownBD
I've been selecting ALL English subtitles for each rip - unless it's clearly a Director's Commentary.
So, I assume if the movie in question has forced subs, that I'm at least ripping them, right? How do you ensure that the subs are displayed correctly during playback?
post #107 of 556
Not necessarily
There are 3 ways a DVD can have forced subs. 1) embedded in the video (e.g. Lord of the Rings) in which case you don't have to do anything special, 2) they are in a separate forced subtitle track (e.g. Star Wars Episode 4... greedo scene) and 3) they are embedded in the normal subtitle track (don't have an example that does it this way).
For 2), you would have to figure out which subtitle track it is and rip it. This involves trial and error although the forced subtitle track will usually be much smaller than the others. When using DVD Shrink, you would want to tell it to always display that track or else you would probably have to manually tell your movie playback program to display it. To do this, when you drag the main title over to the left-hand side (when re-authoring to only select the main title track), right-click on the title and select "Set Default Streams". Go to "Dispay the following subpicture stream" and pick the forced subtitle track (this is where you set the default audio track as well if you ever want to do that). If you don't do this, I'm not sure if your movie player has a way to know which track is the forced subtitle track and thus, if it can automatically play it or not... I could be completely wrong though. This is how I've been doing it for a few years now.
I don't know how to do 3) as I've yet to encounter a DVD that does it that way. Can't help with clown BD either as I use eac3to + bdsup2sub + mkvmerge.
post #108 of 556
Thank you for the summary! That helps a ton!!!
So, it seems like method #1 and #2 are the most common then? Do the same 3 ways apply to Blu-ray as well?
If there is a forced sub track it will show up as a second English track, right? So I'm guessing I can cover most of my bases (with DVDs in DVDShrink at least) by setting the default stream to the smaller of the two tracks?
ClownBD is extremely similar to DVDShrink, and even incorporates eac3to + bdsup2sub like you do. There is an option to dynamically apply only forced subs to the rip. I'm about to run a test with Iron Man.
post #109 of 556
I think so, and yes. For Blu-Rays, when I use eac3to, I rip out all english subtitle tracks. When eac3to is done, it will describe each subtitle track and say if they contain any forced subtitles or not. I then run whatever subtitles that contain forced ones through bdsup2sub and tell it to only extract forced subtitles (I don't bother with the regular, non-forced subtitles in my rips). I guess clown bd does the same thing (maybe I should actually try it). I then run them all through mkvmerge.
post #110 of 556
I think ClownBD does all of that automatically... but I'm not sure. It's definitely worth checking out though! Very easy to use program.
post #111 of 556
Yup pretty much don't have to do anything with MPC-HC these days. Nice to have subs for BD/HD playback I'm watching Mongol BD right now, zoomed and sub'd.
post #112 of 556
It seems like you guys all have a good handle on this... but I figured I might as well share my method.
I like to use DVDShrink and ClownBD to strip out everything except the main movie, a single soundtrack and any forced subtitles (if applicable).
Obviously, if there's only one English subtitle track, that's not going to be forced. If there's more than one - and the second isn't labeled director's commentary or anything similar - there's a good chance the second one is forced (if it's not English SDH, which adds sound effects subtitles).
To double-check, I just play the move from the disc in TMT3 (anything except 7MC should work well). I quickly toggle through each English subtitle. Typically, if one is forced, it's going to be the last on the list and the one already selected when you start the movie.
And then just line that up in DVDShrink or ClownBD. If the forced track was the third English track in the DVD menu, then it will be the third track in both ripping softwares (so far so good at least). A nice option in DVDShrink is that it tells you the size of the track - forced tracks are usually much smaller than any other subtitle track.
In DVDShrink, you can select the default streams and tell it to play the subtitle track you selected. In ClownBD, it does it for you if the Forced Subtitles box is filled in (not checked, but solid color) in the ripping options.
EDIT: I found an easier way. I just run the disc in TMT3. If a subtitle track is playing by default, then I rip it as forced so my rip will play just like the disc.
post #113 of 556
2012 has some forced subs.
Mike
post #114 of 556
Mike
Just noticed that as well, audio track #9
post #115 of 556
Thanks for keeping this updated guys, I have not been buying any movies lately.
post #116 of 556
Taken:
Track 11 is the forced subs
post #117 of 556
I just ripped the original Mummy in Mike's program & it didn't find the forced subs. Any idea why?
1. What can I do with the subtitles files it found to create a forced subtitle file?
2. Can any of you guys email me .sup or idx or whatever file for that movie for me please?
post #118 of 556
The Mummy doesn't have forced subs, they are burned in (I just confirmed with my mkv)
post #119 of 556
30 Days of Nights - Track 9 is the forced subs
post #120 of 556
This is still being kept up to date correct? I could have sworn Amadeus had forced subs.. I guess not.
