And the the bug is that Audyssey MultEQ may be completely broken! So the feature that should help your sound the most could be ruining it.
You could be affected by this and not even realize it, as I was, until I looked into it further.
Cause/Solution Found! (Sep. 30, 2009 Update):
After sending my [second] AVR-1909 to Chris from Audyssey for testing, he confirmed the primary problem of lossy DD/DTS bitstreams being wrongly decoded when MultEQ is enabled. After sending his findings to Denon engineering in Japan, they found it to be a firmware bug in early units! It was then inadvertently fixed along with an update for an iPod Video problem, but units manufactured as late as Nov. '08 could be affected.
Models affected: 1609/589, 1709/689, 1909/789, and 2309/889. The 2809/989 is not affected since it uses MultEQ XT.
For the 2309 only (not 889!): Serial numbers xxxxx15241 and lower were manufactured with the buggy firmware. If you haven't already installed a newer firmware that resolves the issue (e.g. iPod Video fix), please see jdsmoothie's firmware updates post and contact him to install the update yourself.
Again, this does not include the 889! Only the 2309 has the RS-232 jack required to install firmware updates.
For all other models, you will have to contact Denon Customer Service and either take your AVR to a Service Center or create an SRA Request to send your AVR to Denon to have the firmware updated.
Check the firmware to quickly determine if yours has the bug (versions verified on the 1909 and 2309 so far). To view firmware information:
1) With the AVR in Standby (red ring), power off completely with the small ON/OFF button
2) Press and hold the DYN VOL and VIDEO SELECT buttons on the front panel
3) Power it back on with the small ON/OFF button; it goes into Standby (red ring)
4) Release the DYN VOL and VIDEO SELECT buttons, then turn it on with the large On/Standby button (green ring)
5) Once it's powered up, press STATUS to cycle through to the firmware versions
***NOTE*** STATUS will continue to function this way until you cycle the power OFF and ON with the small button (Standby doesn't cancel this mode)
Fixed firmware versions are as follows (lower/older have the bug):
For 1909 and 2309 (probably 789 and 889 also): [Main: 00.90, DSP1: 45.43]
For 1609/589 and 1709/689: To be determined/verified, please report!
To summarize: The main problem is incorrect decoding of lossy DD/DTS bitstreams when MultEQ is enabled, resulting in overblown bass. Some other issues I suspect are related, because they didn't exist on the AVR-590 I tested, and I'm hoping they're resolved with the new firmware: 1) Incorrectly calibrated speaker trims and/or master volume setting, affecting the operation of Dynamic EQ/Volume; and 2) The overall level of bitstreamed Dolby TrueHD is about 2-3dB lower than player-decoded PCM. (I was not able to compare DTS-HD MA.)
Revised original post and information:
For those who haven't seen my posts in the Audyssey thread or the 1909 thread, I finally discovered last month that my problem of inconsistent and wrong audio was solved when I happened to turn MultEQ Off. I sent my unit to Denon to be fixed and they sent back a refurb that has the exact same bug, so I'm now confident that others out there are affected as well, since I've had two units that are (and I may have to fight Denon to do something about it
Update: Denon has said they can replace it, with a new unit this time).
On Sep. 4th I picked up a new model AVR-590 from Best Buy (temporarily
) to check it and absolutely rule out anything specific to me (which I already had; I know what I'm doing). And yes, although I wasn't exactly sure what I'd find, MultEQ works perfectly as it should, unlike the two 1909s.
The primary problem is with MultEQ enabled (Audyssey curve, Flat, or Bypass L/R), bitstreamed Dolby Digital and DTS signals decoded by the AVR sound much different than the same soundtrack decoded externally by a player and sent to the AVR as PCM, primarily in the bass from the subwoofer (not sure about other speakers): nowhere near accurate, boomy, overblown, bombastic, etc. It's not a subtle difference at all, especially with Dynamic EQ On (anyone could notice the difference then!).
How to check for the bug:
Lossy listening tests. The simplest is to just use a few movie scenes that you're familiar with and have a good amount of bass (preferably action, explosions), or anything else you think has enough bass to hear.
- Make sure MultEQ is enabled, of course, by the indicator.
- It is strongly preferred to turn Dynamic EQ On (Red light, not Green) to magnify any differences, making it very easy to tell if your AVR has the bug.
If using HDMI audio and a player that can output multi-channel PCM, remember:
- Cannot be used with 1609/589 or 1709/689 (no HDMI audio support).
- You must use a lossy Dolby Digital or DTS soundtrack; not PCM (on the disc), Dolby TrueHD, or DTS-HD.
- Your player must be able to internally decode that soundtrack to PCM; some will only bitstream DVD/lossy audio.
If using non-HDMI audio (only option with 1609/589 and 1709/689) and/or a source that can output 2-channel PCM, remember:
- You cannot use a multi-channel soundtrack (e.g. 5.1), because changing to PCM results in a 2-channel downmix, which will sound "weaker" -- not because of this bug, but because channels are no longer discrete, [some] automatic DRC, loss of LFE channel, etc.
- You must use a Dolby Digital 2.0 track to compare bitstream and 2-channel PCM. (DD 2.0 audio could also come from a HD DVR/STB, for example, instead of a disc, as long as the box can be changed to output PCM instead of the Dolby Digital bitstream.)
It doesn't matter, but I'd recommend first having your player decode the soundtrack and send PCM. Listen to some of your reference material (do it a couple times to get a feel for the sound). Then, switch the player to output bitstream, and don't touch anything else, including the volume. Repeat for each of the few things you're checking -- since bass will be at different frequencies, the bug may be more or less obvious depending on the frequency.
Did it sound exactly the same both ways? Then you're fine, since the bug should have been obvious.
If things sounded different, it doesn't mean you have the bug, since differences between player and AVR decoding could result in a different sound. So first thing to do is set MultEQ to Off and listen again. Any difference wouldn't be as obvious now with Dynamic EQ subsequently Off, so listen a little more carefully. If bitstream and PCM now sound exactly the same with MultEQ Off, you have the bug! (If both ways still sound different, check and turn off things like Dynamic Range Compression, Night Mode, etc. in the player and AVR, and check speaker levels for each signal format on the AVR, until you get each to sound the same with MultEQ Off. Then start over with MultEQ and Dynamic EQ On.
If you are not able to do a comparison with PCM, you can try some subjective tests (with lossy DD/DTS formats):
- With Dynamic EQ On, it should be fairly easy to tell if bass just "seems" overblown.
- You could try comparing MultEQ enabled vs Off and listen for relatively "more bass" overall with MultEQ (but not Dynamic EQ!). Keep in mind this may not be very reliable, since MultEQ is supposed to change the frequency response, which could be all you're hearing...
If you could please check your AVR and report the results (with model and firmware versions), I'd appreciate it!
Like I said, you should be able to check with "real material" and determine just by ear if you have the bug, but for something more scientific, download and burn the DIY Audio Test DVD. There you'll find subwoofer noise similar to the AVR's internal test tone (5.1 DD Tests > Calibration > Levels Check > LFE), which is a steady sound and easily revealed the bug for me. Compare bitstream and PCM using the same "rules" as above (but Dynamic EQ isn't "needed" for these). Or you could use some of the Manual Tones for LFE at different frequencies, to compare by ear or with an SPL meter.
With non-HDMI audio (only option with 1609/589 and 1709/689): You cannot use the "subwoofer noise" since it's in the LFE channel. You can use the Manual Tones for the Left, Center, or Right channels. Check a spread of a few frequencies, and to measure the subwoofer, make sure those frequencies are "far enough" below the crossover for the speaker corresponding to the tone you're using. The correct result is for PCM to measure 3dB lower than bitstream as a result of 5.1 to 2-channel downmixing.
I used that LFE Calibration tone with the AVR's subwoofer pre-out connected to the computer and used Room EQ Wizard's Spectrum analyzer (1/12 octave RTA, 16 Averages) to show a visual representation of the output:
MultEQ Off: PCM vs Bitstream
- Both 1909s and the new AVR-590 sample look like this
MultEQ On: PCM vs Bitstream (Plus the 2 MEQ Off measurements averaged and smoothed)
- Both 1909s look like this, with bitstream completely screwed up
- New AVR-590 sample looks like this, perfect; bitstream and PCM are identical as it should be
You could be affected by this and not even realize it, as I was, until I looked into it further.Cause/Solution Found! (Sep. 30, 2009 Update):
Again, this does not include the 889! Only the 2309 has the RS-232 jack required to install firmware updates.For all other models, you will have to contact Denon Customer Service and either take your AVR to a Service Center or create an SRA Request to send your AVR to Denon to have the firmware updated.
Update: Denon has said they can replace it, with a new unit this time).On Sep. 4th I picked up a new model AVR-590 from Best Buy (temporarily
) to check it and absolutely rule out anything specific to me (which I already had; I know what I'm doing). And yes, although I wasn't exactly sure what I'd find, MultEQ works perfectly as it should, unlike the two 1909s.The primary problem is with MultEQ enabled (Audyssey curve, Flat, or Bypass L/R), bitstreamed Dolby Digital and DTS signals decoded by the AVR sound much different than the same soundtrack decoded externally by a player and sent to the AVR as PCM, primarily in the bass from the subwoofer (not sure about other speakers): nowhere near accurate, boomy, overblown, bombastic, etc. It's not a subtle difference at all, especially with Dynamic EQ On (anyone could notice the difference then!).
)If you are not able to do a comparison with PCM, you can try some subjective tests (with lossy DD/DTS formats):
Please keep members up to date as to how your discussions go with Denon. Hopefully, they will give you another unit to try.
Like I said, your 2809/989 model may be different enough with MultEQ XT that it may never see this issue!
since the bitstream/PCM differences are the same whether the content comes from the LFE channel, or redirected from the mains.
). -30 was pretty loud, and not sure if I would have listened to a movie higher than that (haven't done any serious movie "watching" since getting the new AVR last year, LOL, just TV!). With the 590 though, I had The Matrix at -20 and it seemed like a fine, "normal" level.
