Originally Posted by DR_LaRRY_PEpPeR
After having no sub detected, turn MultEQ Off again, and on the Test DVD, to go 5.1 DD Tests > Calibration > Levels Check > LFE. You should hear the "rumble noise" through your speakers with MultEQ Off. Then enable MultEQ again (Audyssey setting) and see if you still hear the test noise.
With the bug, it should be silent with MultEQ enabled because the LFE channel is MIA instead of getting mixed into your speakers!
As far as I know, this should be a foolproof way to check (though it takes a little work/hassle...), so please report your findings.
With the bug, it should be silent with MultEQ enabled because the LFE channel is MIA instead of getting mixed into your speakers!As far as I know, this should be a foolproof way to check (though it takes a little work/hassle...), so please report your findings.
Here are the results for my 789
MAIN Ver 00.87
Sub Ver 00.29
DSPi Ver 45.41
APLD A2990009
VPLD A2940002
I ran calibration with no sub detected this time and saved the settings -- I put in the test tone and ran it without MultiEQ enabled first -- I head rumble in my front mains.
I turned on MultiEQ (just by pressing the MultiEQ button on the remote) and verified it said MultiEQ:Audyssey on the AVR display --- NO rumble coming from my speakers.
Something else I noticed -- I get a slight hiss from ALL my speakers (your ear has to be right next to speaker) when MultiEQ is enabled --- there is NO HISS when this feature is turned off. Now, I knew about this hiss but I though I was having a slight ground loop issue or something ----
Very odd --- it looks like my firmware version is newer than some, but still not current --- looks like I may try to get this resolved
So no worries...
(It didn't on my 590, and I saw someone with a Dish DVR say the same with their 2310...) When swapping tuners/buffers on the DVR, the 1909 causes another HDMI handshake (doesn't happen direct to TV)... same thing on the 590, except audio was lost after the handshake until the AVR was cycled on/off again. Sure, there are workarounds, which I'd do if I had to, I'm just used to the Standby passthrough working without problems.
), etc. The 2310's display adds what the 1909 had, however.
confused guy who just sent there denon in for servicing.
