I'm having trouble getting sound out of my Home Theater speakers when I am using the PS3. Here's my setup: I have HDMI cables running from both my Cable Box and PS3 into the HTR-6230 receiver, then one HDMI out into the TV. I also have an Optical cable running from the TV into the receiver. When I switch to DVD input, I get video on the TV, but no PS3 audio through the speaker system. I do get PS3 audio through the TV speakers. My suspicion is that I need a separate audio cable running from the PS3 into the receiver. If this is the case, can I run an optical cable from the PS3 into the Optical port labeled "CD," or do I need to go in to the coaxial port labeled "DVD?" The TV audio works fine through the receiver, by the way. Thanks for your help!
Rich
Rich
