AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › TV stand for pending 65 V10
post #1 of 8
Does anyone have any feedback / suggestions on a TV stand? I'm torn between the Bell'o 2061 and the Init 1201.
http://www.bello.com/index.php?parti...ct&prod_id=227
http://www.initproducts.com/pc-200-6...-65-black.aspx
If you have one, or have any comparisons, I'd appreciate your feedback.
Thx!
post #2 of 8
I too have a p65v10 on order!
I went with the unit below earlier this year - older version, but basically the same unit. It is sitting in my family room waiting for my p65v10.
I researched stands for several months on the net and in person and was disappointed with all of them except this one. I did not trust units with glass tops as I needed something that could hold a 65" plasma. I did not like most furniture units as they were usually made out of particla board (or something like that which is not solid real wood). Also, I needed something that could hold a large center speaker. This unit had excellent build quality, came well packaged, and had cool design items like built in venting. Can add fans, extensions, etc..
Extremely well made...solid wood throughout..believe me, I am VERY fussy and am well satisfied (and I do not say that often). Good people to work with.
http://www.standoutdesigns.com/store...nsole-p322.htm
good luck with your p65v10!
post #3 of 8
If you have a membership to one of the warehouse clubs, I'd check there. I recently purchased an entertainment center from sam's online and it's a really nice unit. Solid wood, came fully assembled - delivery was 200 but it was still cheaper than every other place, and it looks great. I'm talking half the price of other places, so even if you don't have the membership, it pays for itself with the one purchase.
However I did go to lowe's and pick up some casters to help with mobility for when I need to get behind it instead of using the legs which came on it.
post #4 of 8
i went with the bello model you listed for my 65s1. google search, you can find it for under five bills delivered
post #5 of 8
Thats one sweet unit.
bello smeello.
post #6 of 8
good furniture is not cheap.
post #7 of 8
That is a nice one...but for that much, I'd buy another TV!
post #8 of 8
Thx!
Plasmas belong on the wall, the CRT days are long gone.
