AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Plasma Break-In (Slides/DVD): Purposeful or Pointless?
Plasma Break-In (Slides/DVD): Purposeful or Pointless? - Page 5
post #121 of 129
Which break in slides/dvd to use ? Seems like D-nice has expertise with Panasonic. Are his slides for break in specifically for Panny Plasma's ? Evangelos DVD are more inclined for Samsung Plasma's correct ? I've ordered Evangelos DVD for my 58B650 arriving tomorrow. Right Choice ? Will the Sammy instruction manual state how to transfer the DVD to memory card ? I'm new to memory card is this the best way to use the DVD for breaking in ? Does the dvd play on a loop ? Can I use a Oppo 970 DVD Player to play the DVD over a prolonged session ? Will it hurt the DVD Player ? I also have a Panny BD-35 any preference as to which DVD player. Or, is the memory card the best way ? How do I do the memory card ? Ethernet cable to TV ? Will I need to download anything ? Help please from tho's in the knows.
post #122 of 129
I just down loaded the slides you can find on this thread and put it on a usb and used that. the t.v. will run them as a slideshow.I ran the slides all night and watched normal programming during the day with the contrast turned down for 150 hrs
post #123 of 129
Perfect plan!
post #124 of 129
My sig has a link to the 120 slide set which some techy people reported are better than D-Nices because of the gradation between slides and the ordering
post #125 of 129
could someone please check this link, i tried it doesnt work. please advise another link if there is any. i am looking for sildes thaT are already 16:9.
thanks for the help.
post #126 of 129
I everyone,i am fairly new to this forum and I was looking for d'nice slides and break in guidelines. Anyone could direct me to the right direction?
post #127 of 129
I would put your plasma into THX or Cinema sit back and enjoy as there is no point in slides, then after about 500 hours maybe consider a calibration.
post #128 of 129
I want to log some break-in hours on my new ST30 while I sleep. Anyone see a problem with playing a movie in super slow-mo, so that it takes a good 8 hours to get through the whole thing? My DVD player doesn't let you automatically loop movies, is why I ask.
post #129 of 129
Wouldnt the scroll bar be static?
