I've been sitting on this for a time, and have now been given the green light.
Mico is a new " Grand Cinema" line from Sim2, incorporating LED light source. The Mico 50, single chipper, is the first machine in the line. Due December.
No price yet, but based on the spec I expect it to be expensive for a single chip unit
but here are some bullet points.
1.0.95" 1080p DLP® darkchip 4 chipset
2.LED light source, typical life estimated at around 30.000 hours.
3.Contrast ratio up to 100.000:1
4.New color filters,color gamut >128% NTSC, >180% Rec. 709
5.instant on/ off.
6.Throw ratio ....1.5-2.1:1 (T1 standard); 2.1-4.0:1 (T2 optional)
7.Motorized Lens shift V +60% / - 25%, H +/-8%
8.Special video adjustments- NR,Luma and Chroma transition filters
9.Other special adjustments Dynamic Black technology, Memories, Zoom/Crop, Color temperature control and Gamma Functions
10.INPUTS/OUTPUTS
Analog 1 x Composite Video (RCA)
1 x S-Video (mini Din 4 pin)
1 x Component Input (3x RCA)
1 x RGBHV/YCrCb (1x D-Sub 15 pin)
Digital 2 x HDMI – HDCP compliant
Miscellaneous 1 x Wired remote (3.5mm Mini Jack)
2 x OUT 12V (via DC Jack)
Control 1 x USB (B type connector)
1 x RS232 (Mini Din 9 pin)
11. Lighting system-Luminus Phlatlight PT120 R/G/B LEDs. http://www.luminus.com/content1092.
5.instant on/ off.
10.INPUTS/OUTPUTS
