Crank 2, released today, took over an hour for a AV and Computer expert to load this film. I would get a square of about 8" of actual video on a 60" display after waiting 2.5 minutes.
First I updated my Panasonic DMP-BD35K firmware via the internet, which to this day never hicupped on any movie. Restarted, no change.
OK so I left it hooked up the internet, restarted again and this time the movie said it was checking on updates. Still I would not get pass that 8" square of video.
Ok so I then put in my SD memory card, restarted, and after downloading, which also took at least two more minutes on a 16 Mbps internet line, now I get a EULA for Lionsgate BD-Live site. I selected "I disagree" and sure enough the movie would still not load.
OK one more time and I selected "I agree" and wouldn't you know it the movie actually started.
This is the bottom line on getting the movie to play:
It appears that this problem disc will not load on certain 2.0 profile players unless you use an external memory card.
All 1.0 and 1.1 profile players such as the Panasonic BD-30 or Sony's BDP-300 or 500 will not have a problem because they are not BD-Live capable.
All players that are 2.0 profile, that have built in memory, i.e. the PS3 or the OPPO 83 will not have this problem.
All of this would have been a walk in the park if the studios would put a simple system requirement notice on the back cover stating " 2.0 profile players must have either internal or external memory installed for this movie to load correctly."
