AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › BOCS Index/Answers
BOCS Index/Answers
post #1 of 6
Howdy
In an effort to better support questions about the BOCS product, I started this thread basically to be an index only. If you have a problem or question on a BOCS product, someone has probably already asked a similar question somewhere on AVS - and this should be a fairly simple way to find your answer quickly.
Our website - under the support section - has a chat window or you are always welcome to call or text me on my cell (720) 206-4114
I'll edit this post when new questions/answers are posted on AVS.
Review #1:
Review #2:
Do I lose channels when I install this? Do I need a BOCS in every room?
How do you not step on other cable channels?
How many channels does it distribute and how many simultaneously?
miamicanes suggests a whole new product: http://www.avsforum.com/avs-vb/showt...6#post16474946
http://www.avsforum.com/avs-vb/showt...3#post16478133
How to integrate with a receiver:
Video Quality:
Will it work with HDTivo:
Work with Logitech Harmony remote:
Work with Slingbox:
Playback with an FM receiver:
http://www.avsforum.com/avs-vb/showt...5#post16521245
http://www.avsforum.com/avs-vb/showt...8#post16722798
Does the signal need to be amplified if over 100' cable?
How can you tell if Supercombiner is powered?
Supercombiner runs hot:
Can I use the remote on multiple TVs?
http://www.avsforum.com/avs-vb/showt...0#post16753940
I want a supercombiner that passes CATV without being powered:
How much drop is in the Supercombiner:
I need an IR code for something not already in your database:
Why does the repeater need to be programmed?
Remote control range issues:
http://www.avsforum.com/avs-vb/showt...9#post16756359
http://www.avsforum.com/avs-vb/showt...5#post16799675
http://www.avsforum.com/avs-vb/showt...2#post16799722
http://www.avsforum.com/avs-vb/showt...4#post16799804
Keys on the remote do not work quite right with some learned codes:
Should I use CATV or Antenna cable as the "base":
Can you do more than 3 sources?
Will this work with DirecTV?
http://www.avsforum.com/avs-vb/showt...8#post17141918
http://www.avsforum.com/avs-vb/showt...4#post17142014
High Definition: (The latest update)
http://www.avsforum.com/avs-vb/showt...6#post17141976
Will this work with ZeeVee? And how?
Other things that do High-def:
http://www.avsforum.com/avs-vb/showt...7#post16758567
www.zeevee.com
[EDITS below]
What's with general IR targets not workign well with LCD/Plasma TVs AND the optimal things to look for in a wireless remote
Can I Use multiple CATV drop amps in a home?
I get hum lines on some or all of my equipment, what can I do?
Again - this post is only for convenience, if I can get someone to addit to the main BOCS thread or if it offends anyone I'll remove it. In the meantime, I'll do my best to keep it updated.
Thanks again
David Feller
www.bocsco.com
post #2 of 6
Nice work, David
post #3 of 6
www.bocsco.com/tivo.php
$299 for the system, free install kit and extra free remote
(I'll try to keep this updated with deals as they present themselves)
post #4 of 6
Originally Posted by David Feller View Post
There are apparently 4 refurb units going for $220 each on an AVS classified ad here
Only 2 left...
post #5 of 6
Updated the main entry with links to IR interference issues and how to choose an optimal RF remote system
David
post #6 of 6
Not sure if this is the best place for this but I wanted to publicly thank David for his help during an install last Friday. I thought I had it all figured out until my Directv installer showed up to install my new HD DVR and told me I couldn't do what I wanted to (multiplex off of the two sat lines running to me den to my legacy DVR's). I chatted with David briefly online and he called me at home 5 minutes later to discuss the problems. He answered some questions my installer and I had and we were on our way.
Thanks again for the great support.
-Pete
(Long time lurker here)
  Back to Forum: Home A/V Distribution
