AVS › AVS Forum › Video Components › Home Theater Computers › Graphics card recommendation
post #1 of 3
I'm planning to buy a new graphics card.
Don't wanna spend more than 90 dollars.
I will put it on a normal pc, ATX tower.
My main concern is about the 0-255 and 16-235 settings, and the options the drivers offer. I just want to know if I should get an ATI or a NVIDIA card.
I will just use it to watch videos, never for gaming.
post #2 of 3
For what you are doing with it the HIS 4670 should be fine has hdmi and dvi. I have 3 of the older verisons in 3 other builds works fine, just wish I got this one.
post #3 of 3
If you can, wait for the Nvidia Geforce GT 220 retail version that supports full bitstream decoding for H.264, VC-1 & MPEG2 as well as 8 channel LPCM support.
http://www.avsforum.com/avs-vb/showthread.php?t=1161405
http://www.nvidia.com/object/product...gt_220_us.html
