RadioRA2 will directly work with the GrafikEyeQS as long as the unit is the wireless model. If the GrafikEyeQS unit is not wireless then it will not work with the RadioRA2 system.
As a long time Vantage dealer, you should consider a Vantage Infusion system with either ILT or RTS control of the ultra quiet Somfy Sonese motors for the shades.
In addition to conditional logic and astronomically timed events, you can wire for future additions to the system, and it is always backwards compatable.
I can provide more info if you need it.
Call Lutron Customer Service to get a list of local RadioRa2 installers, or potential installers. I bet most of the HomeWorks qualified installers will be signing up for Ra2, so you could probably get a list of installers from the website. http://www.lutron.com/wtb/wheretobuy.aspx?cid=0
What's the premium for GrafikEyeQS wireless? A percentage would be adequate. And when will this be available?
Overall, the RR2 system is dramatically less expensive but the cost of the new multi-button controllers has not been disclosed. How do these conmpare to the old controllers? Again, a percentage is fine.
Thanks-
GE QS is now available. The price is based on what you plan on controlling with it, ie. shades, light loads/type. The Ra2 keypads are $299 and the Hybrid KP will be $449.
I'm interested in a 4 zone wireless GrafikEye QS without shade control (which could be added later, no?).
I understand the benefits of RR2 and they are compelling but I already have a simple RR1 installation. If I keep RR1 system under 32 loads, would there be a performance difference between RR1 and RR2? I understand the feature differences which are significant.
I'm trying to figure out if I should:
1) Scrap the current system (10 loads, 1 repeater, 3 controllers) and invest in a RR2 clone as a starter
2) Keep going w/ RR1; ultimately double it's size and add a Chronos and probably another wall control.
3) Start with QS wireless for the kitchen and incrementally implement RR2. I could run RR1 and QS (as stand alone) unintegrated for a while and then move to RR2
I'm rennovating so my options are somewhat open but I'm not made of money. Decisions, decisions...
If you plan on expanding your Ra Classic installation to the point of needing a Chronos, and are interested in the added features of a RR2 system I would go for it.
Yes- I ran some numbers and agree. Keep it simple w/out chronos- this approach could sustain a modest expansion because RR1 is becoming much cheaper.
Or punt, sell existing to offset the new system- I'm leaning towards this. Incremental expansion is much more affordable with RR2. Lutron did their homework.
But GrafikEye QS Wireless makes no sense if you are starting with RR2...the reverse may be an exception- not sure.
What will the wireless occupancy sensors run?
I went through Ra2 PSP training last week in PA and this is some of what I know:
-Products should be available in 2 weeks (sorry for the pun RTI guys)
-Electronic Dimmers won't available till Jan 1
-Ra2 has three levels. In order to program level 2 (essential) you need burst training. Level 2 will allow you to go up to 100 devices. Level 3 (inclusive) allows you to install up to 200 devices you'll need to be PSP certified.
-Ra2 will not be compatible with any Homeworks products. Just because they are both QS products they are putting walls up so that they won't be compatible.
-Repeaters are counted towards device counts
-Intergrates QS Shades
-No Logic (this biggest reason to be a Homeworks dealer)
-Once programmed with the software you cannot manually make changes. But it will have a web server installers can log on remotely to make changes.
-Software is really easy to program. You go through and create the system in the software and go around to each switch to address it into the program and that's it. No more running around for each scene
-Each button on a keypad can either do scene or room control
-Grafik QS's are pimped out! Any keypad in the house can control a Grafik scene or specific light level on the QS. No more being able to only control a scene button. Completely wide open control.
-T-Stat's won't be out for a while and they aren't even sure how they will work
-Ra2 is faster than the current Homeworks processors (very very fast)
-Homeworks wireless won't be out until 2011
*Not sure on the wired time frame*
-Homeworks will have the same type of GUI that Ra2 has but on steriods of course
-They were taking suggestions for mobile phone control but they said they had nothing done yet.
-100 phantoms
-The main repeater has a built-in astronomical time clock
-To go from 100 to 200 devices you need to add another main repeater but there is no goofy bridging mode
-Did I mention fast
-Car visor controller can do 4 garage doors. This is not a push button type controller anymore and most likely will sit up by the garage door openers
-Foundations package is $4399 suggested list price:
7 600 watt dimmer
3 1000 watt dimmers
3 accessory dimmers
3 wall controllers
3 table tops
Main Rep and 1 Aux Rep
Car Visor controller and 2 car visor controller
*the thought behind this package is that the customer would want to expand that's why they have so many keypads and table top controllers
QS is their wirelss platform but they will put physical limitations up so you cannot use Ra2 with Homeworks QS. It is possible to communicate with each other but it won't happen.
They have a wireless occ sensor and a vacany sensor. The occ sensor can do both but due to California's crazy rules and regs you can't have the option to shut off the vacany setting so they made just a vacancy sensor. You can have the sensor shut lights off if no motion is sensed for more than X mins. Or if you walk into a room the occ sensor can trigger a scene or turn on a specific light. Very cool!
So, should I wait a year or more for HW QS Wired, or go Ra2 now? (rhetorical, of course)
If I decide to wait, any suggestions on how to wire for HW QS Wired? Lutron has gotten away with avoiding twisted pairs for so long that I have doubts they'll switch.
