I've heard they are working on being able to pull the file from the repeater, but at this point if you didn't create it or the homeowner wasn't given a copy you're stuck...
Lutron has finally announced the release of the seeTemp thermostat set for Radio Ra2. Most of you probably already got the email from Lutron, as did I. In it you may have found links and instructions to a webinar that isn't where it is supposed to be. If you follow the link (
Click Here) you will need to login or register for first time users, then enter the Pin code' = RADIORA2, Then you will find a webinar called Lutron seeTemp Overview for RadioRa2', and click launch. In the email it called out webinars 2011 but I couldn't find it by that name.
Here is a summary to answer most immediate questions:
Basically it will replace most standard 24vac thermostats. There is a pre-qualification checklist on the webinar to see if your system will work with the seeTemp system.
There are 3 basic components:
1. SeeTemp Wall Control (I'll call a keypad, because basically that's all it is - Powers from 120vac or 24vac, can gang with other switches/dimmers/devices)
2. Remote Battery Powered Temperature sensor (Self Explanatory - Placement is key as adverse temperature from exterior walls, other devices, direct sunlight or shading from cabinets, doors etc.. can affect how well this will work - multiple sensors are averaged together to one controller)
3. Controller (multiple controller & sensors can be used for Zoned' systems, The controller(s) will go at the HVAC and in range of the RA2 system)
The wall station is not required if you are using and I-something (phone/pad/touch) or now android. Or if you plan a more complicated integration with 3rd party touch screens. Software version 4.1.xx is required.
The tutorial on the webinar is really boring, but probably great over view on HVAC. If you are not familiar with HVAC, I recommend you watch it all.
We have an initial order placed and several requests. We have yet to get exact pricing but from the webinar list pricing is:
seeTemp Wall control [LRD-WST-F (or C)-XX(Color) ] $199.00
see Temp Wireless Temperature Sensor [LRF2-TWRB-SW (or MN) only snow white or midnight black] $120.00
Thermostat Package [LR-HVAC-PKG-WH (1ea, wall control, sensor, HVAC controller ~ White only)] $599.00
Integration Package [LR-HVAC-INT-SW(or MN) (HVAC controller & Sensor only)] $449.00
For those of you that have placed orders with us, you know we offer a hefty discount of LIST pricing, have the best RA2 pricing, and great support. Please
contact me for a quote if you are interested.
