Originally Posted by Fiasco
That reply was for a retrofit.
For new construction I would have the electrician put a receptacle and 8ans switch in a 2 gang box at the landscape transformer location. You should save on labor and wire since the electrician won't need to pull 3 way switch legs through the house. Same thing for your exterior floods. Normally you would have multiple locations in the house to control exterior lights. With keypads you don't need to that labor or wire.
Of course, having each pair of flood lights at each location have their own 8ans switch solves the problem but is pretty pricey. I think perhaps if I connect a few of the pairs, I can reduce the number of 8ans switches and make the cost reasonable. There is no reason I can't have, say, 3 pairs of lights come on together--one end of the house for example. And, gang the other end of the house together--maybe do the whole thing with 3 8ans switches.
I think we have solved this one. THanks. R
