Originally Posted by
guitarman
I know they're expensive but I really liked the one I tested, now it's even better. My buddy said they will give me a super deal for helping them with so many things. Think I'll give it a shot and try to pick one up, the LCD just isn't doing it for me.
Enjoy your new high end machine.
Thanks guitarman! I'm with you about the LCDs not quite doing it for me either.
Got mine on Friday, image quality is really really good. Although the individual I received had few quality control problems.
- Lens shift knobs are some what "loose" - not having the active range always in control meaning there are come caps between the working and nonworking areas on the knob's range.
- About 6cm (2.4") crack on the top of the case (
photo1,
photo2).
- Problems with my PS3; picture freezing for few seconds, image cracks, breaks and have some weird lines, loosing source over and over again. Although I recall these same PS3 problems with my earlier HD80 before upgrading the fw.
Current fw is 1.08, is it possible to do the upgrade my self?
I should receive a new pj in a couple of days, it hopefully fixes the problems i'm having.
