Originally Posted by
guitarman
When you read back in this thread you see members that download the firmware and confirm 24fps is now working, maybe if you PM them you can get the answers you need.
I'd re-run the firmware it woulnd't hurt.
Tom will reinstall the firmware this weekend and let you know if anything changes.
rafparedis
I have had no additional issues with 24p playback when upgraded to 1.11. Playback devices are ps3 and tosh HD-Ex1. I think it's safe to say that 24p is played back at 48Hz. Can you check if the frame interpolation settings are off?
before the upgrade I experienced mild jerkiness when playing 24p material, not anymore
rafparedis when I output 1080p 24 from my Oppo the Optoma display reads 1080P 24HZ on screen not 48hz so maybe this is why my display is having bad color/gliches when playing 24fps. Is the player or the projector suppose to step this up to 48hz? My guess is this is why I am seeing problems and you are not as I can definitely here the color wheel slow down when selecting 24fps in the Oppo.
"Can you check if the frame interpolation settings are off?"
If this is the pure motion option on the Optoma then yes it was off.
Ras
