Samsung S, A, C Panel Differences: 2009 LCD Line-Up
(Other thread talking about the same issue: http://www.avsforum.com/avs-vb/showt...g+panel)<br />
I'm hoping to sum it up in this post/thread.
-------Introduction--------
I've been trying to tell people about this 'panel' issue; but many people disacknowledge and disprove.
Truth be told; Last year, Samsung started using AMVA (AUO) and SMVA (CMO) panels, but only with the A630 model and down - A650 and up used strictly SPVA panels. This year, every set seems to involve more than one panel including sets higher than '630'. (Based on all 2009 CCFL-LCD Lineup)
Some do acknowledge about this issue to an extent; but believe there isn't ANY difference. Sorry, but there is a difference and people need to know about it.
I'm not trying to promote any other manufacturer and Samsung for that matter, nor am I trying to suggest not to buy Samsung. Just pointing out that reality is not always based on how we wished it would be.
All information gathered is either speculation and proof by codes, panel information, service manual, service menu, customer reference, and so on.
All information has been suggested as 'true', 'confirmed' and accepted. If you feel the need to deny, please refute instead.
Thank you.
Alright, so the question is, "Is there any truth to the difference in quality between these panels?" One word, "YES!"
Samsung has been recently doing some fishy marketing tricks by using several panels on their sets and on particular sizes. For instance, the 55" B650 (Which I own) all have CMO-SMVA panels; while the other sets (..40, 46..) using several panels.
It's not something to overlook!
1. We have the letters S,A, and C appearing on Samsung monitors and TV.
2. We have news releases of Samsung procuring panels from Chi Mei, AUO.
3. We have owners of monitors and TV complaining of performance issues.
4. We have pictures of various pixel geometries.
5. We have a picture of AU Optronics label through vents of a Samsung TV.
6. We have a Samsung Tech who won't deny it in the CNET forum.*
7. We have global reports of the same issues with Samsung product.
There has been no feasible alternative for the letters S, A, and C put forth other then the 3 panel makers. The panel differences have been noted in smaller computer monitors. *The Samsung tech would not be prohibited from commenting, as he says he is, if the theory was false.
Here is a complete list of panels based on service manual collections (Thanks to Mikl1984)
Note: The list of part numbers (panels) is what your television should get.
In other words, the list displays the main panel on that particular
model. Not all panels are listed because of lack of code numbers regarding
other panels.
The service manual does not list all panels.
These case will be useful to find out:
1. Sticker info
2. Panel Codename in Service Menu
3. Pixel Photo
4. Most exact evidence - sticker on panel inside TV (Disassembling required in most cases)
Check www.samsungparts.com for more information on television parts (Use list below)
Second column = Samsung#
Third column = Part#
A complete list of panels *(Please read note):
*Note: The list of part numbers (panels) is what your television should get.
other panels.
Here we have a list of panels used on Samsung B650 and B750.
Updated picture panels Samsung B650/750 *(Please read note)
other panels.
Samsung B750 Controversy (52" vs 40" and 46")
Here we have another complete list (LE)
Like I posted above - there are ways to figuring out what kind of panel you have.
Usually you should be aiming to get the Samsung panel (SPVA), then AUO, and lastly the CMO panel - in terms of viewing angle performance.
1. *Sticker Info (Version #): http://i160.photobucket.com/albums/t...02-label-2.jpg
(Back panel sticker) http://farm1.static.flickr.com/245/5...09a460f5c6.jpg
2. **Panel Codename/Firmware: *No longer feasible*
3. Pixel Structure: http://i160.photobucket.com/albums/t...l-compare3.jpg
4. Internal Panel: http://www.avsforum.com/avs-vb/attac...8&d=1232646182
*The 'Version' on the sticker can indicate what panel you have (at least what panel that set should have)
Anything starting with the following letters on the Version is:
S = Samsung
A = AUO
C = CMO
At least this is how we add some definition to them;
S= Super
A= Average
C= Crap
Note: In these definitions, they only compile towards it's viewing angles and NOT the actual picture performance as it will differ within the context of the panels
** (No longer feasible)
Vendor (A: AMLCD, D: CMO, L: AUO, I: CPT)-producer
Panel frequency (6:50 / 60Hz, 1:100 / 120Hz, 2:200 / 240Hz)-refresh rate
Panel (A: AG, T: TN U: UC)
Resolution (F: FHD, H: HD, U: UD)-resolution
Panel 1st/2nd (1st: 0, 2nd: 1 ...)
BLU (C: CCFL, L: LED, E: Edge LED)-type backlight
Technology Differences
S-PVA, for example, is comprised of 2 sub-pixels each with 4 domains - so you effectively have 8 domains per pixel.
S-MVA (CMO) is similar.
A-MVA is actually somewhat more complex, but is also comprised of numerous domains per pixel.
S-PVA however will clearly have better color reproduction and off-angle viewing angles than the latter two MVA panels in regards to the comparison with the use of panels currently on the 2009 model line up. Picture quality can be discernible between S-PVA and *-MVA and it's ANSI contrast ratio is somewhat higher due to it's pixel formation and compatibility with Samsung's polarization; optical diffusion and lenses : http://www.hardforum.com/showpost.ph...5&postcount=10
To add contrary, it has been said MVA has it's capability to surpass PVA. AUO and CMO are two Taiwan companies who constantly improve MVA, that differences between PVA and MVA can be quite hard to discern. CMO has been mass producing large LCD panels for quite some time, as AUO just recently started. CMO technologies today are capable of producing picture quality surpassing PVA. However, it is up the supplied manufacturer to choose what type of panel should be used. Clearly Samsung did not choose to use the latest panel offerings from CMO and even AUO. In regards to the other information about CMO below and above, don't think negatively about CMO as they are an innovative company. It's just clear that Samsung decided to use an inferior AUO and CMO panel in their current line up.
http://www.tftcentral.co.uk/articles...chnologies.htm -> This site can be used for good reference, but keep in mind that some marketing fluff still appears in those descriptions.
Viewing angles on *VA panels is like are aguing about one being 5/10 and the other being 6/10 while IPS panels are 9/10.
But I have also see significant viewing angle variations on different samsung panels. A huge factor is personal tolerance to various issues. Also store conditions make it much harder to see issues (duh) so you can't compare what you see at home to what you see in store.
Bottom line is you can't rely on other peoples subjective opinions about panels. You have to see for yourself, ultimately you can't tell until you have it home. By then it may be too late. So it is a tough minefield to slog trying to get a good Home screen. But still more information never hurts. I want to know what I am buying. (guidryp) And so should you.
http://www.youtube.com/watch?v=fy41W...eature=related
This has been going on for YEARS
- Link: http://investintaiwan.nat.gov.tw/en/...006110801.html (The Korean government erased it
- Link: http://www.emsnow.com/npps/story.cfm?pg=story&id=37882
- S, A and C do represent the panels used as other posters have said and there seems little point in Samsung denying this any longer apart from to covering their backs.
They've covered themselves with this fine print: "The manufacturer reserves the right to make changes to product at any moment without notice."
- Link: PROOF for the Issue http://img4.imageshack.us/img4/391/s...servicepa4.jpg
Service Manual (LE)
Service manual isn't 100% accurate: http://s1.dump.ru/file_download/MjQ5...guMTUwLjYzLjI4
Model:
Repairing/Replacing
Eg. In cases where S panel sets appear inferior part of the the issue could be the substitution of an A or C panel for an S.
Better watch out!
A lot of these Sammy panel differences can't be appreciated unless you compare them side by side. Unless you can decipher the difference. With high-end LCD's; consumers should expect to get hands on 'Samsung' panels rather than having a PANEL LOTTERY. Try comparing the different sets if you can and you'll have to agree with me
Pricing/Variation/Outsourcing
While there are constant variations from set-to-set; what else can be varied?
- Different panels should use different boards. So at least we know - Samsung does not produce AUO and CMO compatible boards to say the least.
- Some users of the (B650) reported that they had an LED lighting below the Samsung logo. While I do own this particular set, I have NO OPTION whatsoever regarding this LED indicator below the logo. Variation from set-to-set?
- Some say Samsung stopped improving their S-PVA panel (hence MVA is now comparable) but instead improves their UCP (Ultra Clear Panel) otherwise the optical components. http://techon.nikkeibp.co.jp/article...73651/fig8.jpg
- We do know that Samsung uses Chelsea (SDP83) & Arsenal (SDP84) video and audio chips. (Confirmed on the A650/A750)
Note: Well apparently they are using SiliconImage as a cost-effective measure to whatever sets. (We do know they use SiI9287 Port Processor)
Differences unknown but INFOLINK hacking has been useful to many Chelsea&Arsenal chip owners
At the very least here is a Sony's main board on their 32" (This is the only picture I can find) http://techon.nikkeibp.co.jp/article...73651/fig5.jpg
- Pricing; Because Samsung deploys mass outsourcing, is this a reason why their products aren't over-priced? I'm not sure but I'd pay more to get the best possible components (esp. from high-range CCFL-LCD series!)
Some Pictures
Viewing Angles:
> You can look at the pictures I posted below. I know it's not that great... so just look at thhowl's pro pics linked below
> Please check this page: http://www.smugmug.com/gallery/98440...69381814_wMcGu
Thanks for all the pictures thhowl! We appreciate it! Model: LN55B650
> *Thanks for the pictures billybob54 Model: LN55B640
L E F T
R I G H T
Picture Performance (S, A, C)
- Will be updating later -
Picture Performance Issues
I'll look forward to adding more information on "S" and "A" panels from other users as I do not have them to test out.
CMO PANELS: RED SMEARING
I've come to realize that "C", the panel that I have on my B650 55", exhibits extreme amounts of red smearing when the picture displays both dark and light colored sources.
- Will update later and post pictures and video's -
Here are great video's that show the problem; thanks k1ng617.
http://www.youtube.com/watch?v=-lF1Jz0o_7g
http://www.youtube.com/watch?v=-Yr67Ndh66Y
____________________________________________________________ __
Conclusion = Bad quality control. We consumers aren't stupid
It's up to you! I wish I could return my 55"B650 CMO television for a TV that has good quality control, or something with a PVA panel. But I was too late. So before anyone gets it fixed or anything in regard - be sure you get the best possible panel, possible! We shouldn't even be worrying of the purchase we made... but it's how it is. If you don't care, then simply ignore it!
Well hopefully you guys do understand!
Thank you.
other panels.
1. Sticker info
3. Pixel Photo
other panels.
Code:
LA32B530P7R BN07-00679D LTF320HA09
LA32B530P7R BN07-00658A V315H1-L01
LA37B530P7R BN07-00643A T370HW02 VC
LA40B530P7R BN07-00645A T400HW02 V3
LA46B530P7R BN07-00685B LTF460HA06
LE32B55* BN07-00640A T315HW02 V2
LE37B55* BN07-00643A T370HW02 VC
LE40B55* BN07-00675D LTF400HA08
LE46B55* BN07-00668A V460H1-L06
LE32B65* BN07-00641A T315HW02 V3
LE37B65* BN07-00644A T370HW02 VE
LE40B65* BN07-00646A T400HW02 V5
LE46B65* BN07-00666A V460H1-LH5
LE55B65* BN07-00695A V546H1-L01
LE40B75* BN07-00694B LTF400HG03
LE46B75* BN07-00637A LTF460HG01
LE52B75* BN07-00696A LTF520HH01
UE40B70x0WW BN07-00700B LTF400HF08
UE40B70x0WW BN07-00734A
UE46B70x0WW BN07-00701B LTF460HF08
UE46B70x0WW BN07-00735A
UE55B7000WW BN07-00702B LTF550HF04
UE55B7000WW BN07-00736A
UE40B8000XW BN07-00698A LTF400HG02
UE46B8000XW BN07-00699A LTF460HG02
LN19B360C5D BN07-00610A M185B1-L02
LN22B360C5D BN07-00620A V216B1-L02
LN26B350F1 BN07-00638A T260XW02 VS
LN32B350F1 BN07-00657A V315B5-L01
LN26B360C5D BN07-00638A T260XW02 VS
LN32B360C5D BN07-00657A V315B5-L01
LN32B350F1D BN07-00657A V315B5-L01
LN26B450C4H BN07-00638A T260XW02 VS
LN26B457C6H BN07-00638A T260XW02 VS
LN32B450C4H BN07-00674D LTF320AP06
LN32B457C6H BN07-00674D LTF320AP06
LN37B457C6H BN07-00642A T370XW02 VF
LN40B457C6H BN07-00650A T400XW01 V7
LN26B450C4M BN07-00638A T260XW02 VS
LN32B450C4M BN07-00657A V315B5-L01
LN37B450C4M BN07-00642A T370XW02 VF
LN40B450C4M BN07-00650A T400XW01 V7
LN32B530P2M BN07-00640A T315HW02 V2
LN26B460B2D BN07-00638A T260XW02 VS
LN32B460B2D BN07-00657A V315B5-L01
LN32B540P8D BN07-00657A V315B5-L01
LN40B540P8F BN07-00661A V400H1-L05
LN46B540P8F BN07-00647A T460HW03 V4
LN52B540P8F BN07-00678A LTF520HB05
LN32B550K1F BN07-00640A T315HW02 V2
LN37B550K1F BN07-00643A T370HW02 VC
LN40B550K1F BN07-00675D LTF400HA08
LN46B550K1F BN07-00685B LTF460HA06
LN52B550K1F BN07-00678A LTF520HB05
LN32B550K1M BN07-00640A T315HW02 V2
LN40B550K1M BN07-00661A V400H1-L05
LN46B550K1M BN07-00647A T460HW03 V4
LN52B550K1M BN07-00678A LTF520HB05
LN22B650T6 BN07-00620A V216B1-L01
LN40B650T1M BN07-00646A T400HW02 V5
LN46B650T1M BN07-00671A LTF460HF03
LN55B650T1M BN07-00695A V546H1-L01
LN52B750U1M BN07-00696A LTF520HH01
LN40B610A5F BN07-00691B LTF400HF10
LN46B610A5F BN07-00705B LTF460HF06
LN52B610A5F BN07-00706B LTF520HE09
LN32B640R3F BN07-00641A T315HW02 V3
LN32B650T1F BN07-00641A T315HW02 V3
LN37B650T1F BN07-00644A T370HW02 VE
LN40B640R3F BN07-00677D LTF400HF11
LN46B640R3F BN07-00671B LTF460HF07
LN55B640R3F BN07-00695A V546H1-L01
LN40B630N1F BN07-00691B LTF400HF10
LN46B630N1F BN07-00705B LTF460HF06
LN52B630N1F BN07-00706B LTF520HE09
LN40B650T1F BN07-00677A LTF400HF03
LN46B650T1F BN07-00671A LTF460HF03
LN55B650T1F BN07-00695A V546H1-L01
LN40B750U1F BN07-00694B LTF400HG03
LN46B750U1F BN07-00637A LTF460HG01
LN52B750U1F BN07-00696A LTF520HH01
other panels.
Code:
Updated picture panels Samsung B650/750 with bit rate comparisons B650 32" AU Optronics T315HW02/ 8bit (AMVA3) The B650 32 "AU Optronics panel mounts T315HW02 / 8bit (AMVA3) B650 37" AU Optronics T370HW02/ 8bit (AMVA) The B650 37 "AU Optronics panel mounts T370HW02 / 8bit (AMVA) B650 40" BN07/81 AU Optronics T400HW02/ 8bit (AMVA3) The B650 40 "panel mounts BN07/81 AU Optronics T400HW02 / 8bit (AMVA3) B650 40" BN81 S-PVA LTF400HF09/ 8bit The B650 40 "S-PVA panel BN81 mounts LTF400HF09 / 8bit B650 46" S-PVA LTF460HF03/ 8bit The B650 46 "S-PVA panel mounts LTF460HF03 / 8bit B650 55" CHI-Mey Optoelectronics V546H1/ 10 bit LCS MVA B650 55 "panel mounts CHI-Mey Optoelectronics V546H1 / 10 bit LCS MVA B750 40" BN07 S-PVA LTF400HG03/ 8bit B750 40 "S-PVA BN07 panel LTF400HG03 / 8bit B750 40" BN81 S-PVA LTF400HG01/ 8bit B750 40 "S-PVA BN81 panel LTF400HG01 / 8bit B750 40" Chi-Mey Optoelectronics LCS MVA V400H1/ 10bit (for which market...?) B750 40 "Panel Chi-Mey Optoelectronics LCS MVA V400H1 / 10bit (for which market ...?) B750 46" BN07 S-PVA LTF460HG01/ 8bit B750 46 "S-PVA BN07 panel LTF460HG01 / 8bit B750 46" BN81 S-PVA LTF460HG01/ 8bit B750 46 "S-PVA BN81 panel LTF460HG01 / 8bit B750 46" AU Optronics AMVA3 T460HW03/ 8bit B750 46 "AU Optronics panel AMVA3 T460HW03 / 8bit (for which market ...?) B750 52" S-PVA LTF520HH01/ 8bit B750 52 "S-PVA panel LTF520HH01 / 8bit B750 52" S-PVA LTF520HE09/ 8bit B750 52 "S-PVA panel LTF520HE09 / 8bit
Code:
The Samsung B750 is Samsung's flagship top of the line CCFL-LCD. To think that the top model should contain the best materials (let alone Samsung component/panels) that Samsung has to offer, it surely is quite surprising that they chose to do the panel lottery. We're quite certain that all 52" B750 contain S-PVA panels. They use "LTF520HH01" and "LTF520HE09". While the differences between the two are unknown, the latter version are believed to be similar but with minor differences. We may not notice anything at all between the two. However, the more common sizes (40 and 46) appear to contain several panels that include S, A, and C. 40" = "LTF400HG03" "LTF400HG01" and "V400H1" 46" = "LTF460HG01" and "T460HW03"
Code:
LE32B55 * BN07-00640A LCD-PANEL;T315HW02 V2 BN07-00640A LCD-PANEL; T315HW02 V2 T315HW02 V2,8bit,31.5 inch,16.7M,16:9,0 to +50,12V,AMVA3,72%,31.5 inch,FHD, 4U-Lamp, w/o inverter T315HW02 V2, 8bit, 31.5 inch, 16.7M, 16:9,0 to +50,12 V, AMVA3, 72%, 31.5 inch, FHD, 4U-Lamp, w / o inverter BN81-02345A A/ST CON T315HW02_V2;T315HW02_V2 BN81-02345A A / ST CON T315HW02_V2; T315HW02_V2 BN07-00679D LCD-PANEL;LTF320HA09 BN07-00679D LCD-PANEL; LTF320HA09 LTF320HA09,SSCZAI,8bit,32inch,16.7M,16:9,0.3635(H)*0.36375(w),0 to +50,12V,SPVA 72%,32 inch FHD LTF320HA09, SSCZAI, 8bit, 32inch, 16.7M, 16:9,0.3635 (H) * 0.36375 (w), 0 to +50,12 V, SPVA 72%, 32 inch FHD LE37B55* LE37B55 * BN07-00643A LCD-PANEL;T370HW02 VC BN07-00643A LCD-PANEL; T370HW02 VC T370HW02 V,8bit,37 inch,16.7M,16:9,0 to +50,12V,AMVA,72%,37 inch, FHD,10S-Lamp, w/o inverter T370HW02 V, 8bit, 37 inch, 16.7M, 16:9,0 to +50,12 V, AMVA, 72%, 37 inch, FHD, 10S-Lamp, w / o inverter BN81-02368A A/ST CON T370HW02_VC;T370HW02_VC BN81-02368A A / ST CON T370HW02_VC; T370HW02_VC LE40B55* LE40B55 * BN07-00661A LCD-PANEL;V400H1-L05 BN07-00661A LCD-PANEL; V400H1-L05 V400H1-L05,8bits,40inch,16.7M,16:9,0 to +50,12V,DJITO, 72%,40 inch,FHD, w/o inverter V400H1-L05, 8bits, 40inch, 16.7M, 16:9,0 to +50,12 V, DJITO, 72%, 40 inch, FHD, w / o inverter BN81-02390A A/ST CON V400H1-L05;V400H1-L05 BN81-02390A A / ST CON V400H1-L05; V400H1-L05 BN07-00675D LCD-PANEL;LTF400HA08 BN07-00675D LCD-PANEL; LTF400HA08 LTF400HA08,SSDZAZ,8bit,40inch,1.67M,16:9,0.461(H)*0.461(W),0 to +50,12V,SPVA 72%,40inch FHD 60Hz LTF400HA08, SSDZAZ, 8bit, 40inch, 1.67M, 16:9,0.461 (H) * 0.461 (W), 0 to +50,12 V, SPVA 72%, 40inch FHD 60Hz LE46B55* LE46B55 * BN07-00668A LCD-PANEL;V460H1-L06 BN07-00668A LCD-PANEL; V460H1-L06 V460H1-L06,8bits,46inch,16.7M,16:9,0 to +50,12V,Flip Pixel, 72%,46 inch, FHD V460H1-L06, 8bits, 46inch, 16.7M, 16:9,0 to +50,12 V, Flip Pixel, 72%, 46 inch, FHD BN81-02394A A/ST CON V460H1-L06;V460H1-L06 BN81-02394A A / ST CON V460H1-L06; V460H1-L06 BN07-00685B LCD PANEL;LTF460HA06 BN07-00685B LCD PANEL; LTF460HA06 LTF460HA06,SSEZAV,8bit,46inch,16.7M,16:9,0.53025(H)*0.53025 (W,0 to +50,12V,SPVA 72%,AG3 LTF460HA06, SSEZAV, 8bit, 46inch, 16.7M, 16:9,0.53025 (H) * 0.53025 (W, 0 to +50,12 V, SPVA 72%, AG3 LE32B65* LE32B65 * BN07-00641A LCD-PANEL;T315HW02 V3 BN07-00641A LCD-PANEL; T315HW02 V3 T315HW02 V3,8bit,31.5 inch,16.7M,16:9,0 to +50,12V,AMVA3,72%,31.5 inch, FHD,4U-Lamp, w/o inverter, 120Hz(MEMC) T315HW02 V3, 8bit, 31.5 inch, 16.7M, 16:9,0 to +50,12 V, AMVA3, 72%, 31.5 inch, FHD, 4U-Lamp, w / o inverter, 120Hz (MEMC) BN81-02346A A/ST CON T315HW02_V3;T315HW02_V3 BN81-02346A A / ST CON T315HW02_V3; T315HW02_V3 LE37B65* LE37B65 * BN07-00644A LCD-PANEL;T370HW02 VE BN07-00644A LCD-PANEL; T370HW02 VE T370HW02 VE,8bit,37 inch,16.7M,16:9,0 to +50,12V,AMVA,72%,37 inch, FHD,10S-Lamp, w/o inverter, 120Hz(MEMC) T370HW02 VE, 8bit, 37 inch, 16.7M, 16:9,0 to +50,12 V, AMVA, 72%, 37 inch, FHD, 10S-Lamp, w / o inverter, 120Hz (MEMC) BN81-02369A A/ST CON T370HW02_VE;T370HW02_VE BN81-02369A A / ST CON T370HW02_VE; T370HW02_VE LE40B65* LE40B65 * BN07-00646A LCD-PANEL;T400HW02 V5 BN07-00646A LCD-PANEL; T400HW02 V5 BN81-02372A A/ST CON T400HW02_V5;T400HW02_V5 BN81-02372A A / ST CON T400HW02_V5; T400HW02_V5 LTF400HF09,8bit,40inch,1.07B,16:9,0.46125(H)*0.15375(w,0 to +50,12V,SPVA 72%,40 inch FHD LTF400HF09, 8bit, 40inch, 1.07B, 16:9,0.46125 (H) * 0.15375 (w, 0 to +50,12 V, SPVA 72%, 40 inch FHD LE46B65* LE46B65 * BN07-00666A LCD-PANEL;V460H1-LH5 BN07-00666A LCD-PANEL; V460H1-LH5 BN81-02393A A/ST CON V460H1-LH5;V460H1-LH5 BN81-02393A A / ST CON V460H1-LH5; V460H1-LH5 LTF460HF03,SSEZFT,8bit,46inch,1.07B,16:9,0.53025(H)*0.53025(w,0 to +50,12V,SPVA 75% ZBD,46 inch FHD LTF460HF03, SSEZFT, 8bit, 46inch, 1.07B, 16:9,0.53025 (H) * 0.53025 (w, 0 to +50,12 V, SPVA 75% ZBD, 46 inch FHD LE55B65* LE55B65 * BN07-00695A LCD-PANEL;V546H1-L01 BN07-00695A LCD-PANEL; V546H1-L01 V546H1-L01,CM54H11A,10bits,54.6inch,1073.7M,16:9,0 to +50,12V,Flip Pixel,72%,54.6 inch, FHD, 120Hz(MEMC), S/C V546H1-L01, CM54H11A, 10bits, 54.6inch, 1073.7M, 16:9,0 to +50,12 V, Flip Pixel, 72%, 54.6 inch, FHD, 120Hz (MEMC), S / C BN81-02395A A/ST CON V546H1-LH1;V546H1-LH1 BN81-02395A A / ST CON V546H1-LH1; V546H1-LH1 LE40B62* LE40B62 * V400H1-LH3,CM40H13A,10bits,40inch,1073.7M,16:9,0 to +50,12V,DJITO, 72%,40 inch, FHD, w/o inverter, 120Hz(MEMC) V400H1-LH3, CM40H13A, 10bits, 40inch, 1073.7M, 16:9,0 to +50,12 V, DJITO, 72%, 40 inch, FHD, w / o inverter, 120Hz (MEMC) LE46B62* LE46B62 * T460HW03 V5,AU46H35,8bit,46 inch,16.7M,16:9,0 to +50,12V,AMVA3,72%,46 inch,FHD, 20S-Lamp, 120Hz(MEMC) T460HW03 V5, AU46H35, 8bit, 46 inch, 16.7M, 16:9,0 to +50,12 V, AMVA3, 72%, 46 inch, FHD, 20S-Lamp, 120Hz (MEMC) LE52B62* LE52B62 * LTF520HE09,SSNZEI,8bit,52inch,1.06B,16:9,0.6(H)*0.6(w),0 to +50,12V,SPVA 72%,FHD 120Hz(AG) LTF520HE09, SSNZEI, 8bit, 52inch, 1.06B, 16:9,0.6 (H) * 0.6 (w), 0 to +50,12 V, SPVA 72%, FHD 120Hz (AG) LE40B75* LE40B75 * BN07-00694B LCD-PANEL;LTF400HG03 BN07-00694B LCD-PANEL; LTF400HG03 BN81-02355A A/ST CON LTF400HG01;LTF400HG01 BN81-02355A A / ST CON LTF400HG01; LTF400HG01 LE46B75* LE46B75 * BN07-00637A LCD-PANEL;LTF460HG01 BN07-00637A LCD-PANEL; LTF460HG01 BN81-02354A A/ST CON LTF460HG01;LTF460HG01 BN81-02354A A / ST CON LTF460HG01; LTF460HG01 LE52B75* LE52B75 * BN07-00696A LCD-PANEL;LTF520HH01 BN07-00696A LCD-PANEL; LTF520HH01 BN81-02356A A/ST CON LTF520HH01;LTF520HH01 BN81-02356A A / ST CON LTF520HH01; LTF520HH01 UE40B7000WW UE40B7000WW BN07-00700B LTF400HF08 SPVA 82% BN07-00700B LTF400HF08 SPVA 82% BN81-02357A A/ST CON LTF400HF05;LTF400HF05 BN81-02357A A / ST CON LTF400HF05; LTF400HF05 BN07-00734A BN07-00734A UE46B7000WW UE46B7000WW BN07-00701B LTF460HF08 SPVA 82% BN07-00701B LTF460HF08 SPVA 82% BN81-02358A A/ST CON LTF460HF05;LTF460HF05 BN81-02358A A / ST CON LTF460HF05; LTF460HF05 BN07-00735A BN07-00735A UE55B7000WW UE55B7000WW BN07-00702B LTF550HF04 SPVA 82% BN07-00702B LTF550HF04 SPVA 82% BN81-02362A A/ST CON LTF550HF03;LTF550HF03 BN81-02362A A / ST CON LTF550HF03; LTF550HF03 BN07-00736A BN07-00736A UE40B8000XW UE40B8000XW M0215 BN07-00698A LCD-PANEL;LTF400HG02 1 SA M0215 BN07-00698A LCD-PANEL; LTF400HG02 1 SA BN81-02359A A/ST CON LTF400HG02;LTF400HG02 BN81-02359A A / ST CON LTF400HG02; LTF400HG02 UE46B8000XW UE46B8000XW BN07-00699A LCD-PANEL;LTF460HG02 BN07-00699A LCD-PANEL; LTF460HG02
S = Samsung
A = AUO
C = CMO
S= Super
A= Average
C= Crap
)- Link: http://www.emsnow.com/npps/story.cfm?pg=story&id=37882
Service Manual (LE)
Model:
Code:
Model: LE32B55* LE37B55* LE40B55* LE46B55* LE32B55 * LE37B55 * LE40B55 * LE46B55 * LE32B65* LE37B65* LE40B65* LE46B65* LE55B65* LE32B65 * LE37B65 * LE40B65 * LE46B65 * LE55B65 * LE32B57* LE37B57* LE40B57* LE46B57* LE32B57 * LE37B57 * LE40B57 * LE46B57 * LE32B67* LE37B67* LE40B67* LE46B67* LE55B67* LE32B67 * LE37B67 * LE40B67 * LE46B67 * LE55B67 * LE40B62* LE46B62* LE52B62* LE40B62 * LE46B62 * LE52B62 * LE40B75* LE46B75* LE52B75* LE40B75 * LE46B75 * LE52B75 *
Repairing/Replacing
Better watch out!
Some Pictures
Viewing Angles:
L E F T
R I G H T
Can someone tell me
