Set up a 2-channel audio system on my computer?
I really could use some advice here. I'm rather new to computer audio but would like to try using my computer as a music server. I have the following gear that I was planning to use for this:
1.) M-Audio Audiophile 2496 soundcard.
2.) Parasound Zamp v.3 Zone Amplifier
3.) Parasound Zpre2 Zone Preamplifier.
I think you can see where I'm going with this. The M-Audio sound card has standard RCA output jacks. Connect it to the preamp and connected the preamp to the power amp and then connect a pair of passive bookshelf speakers. (I haven't got speakers for this yet but was considering picking up a pair of these Infinity Beta20 bookshelf speakers).
I was pretty much set on this setup until I read another thread in this forum that suggested looking into KingRex components. I did a little reading of reviews and concluded that going with a Class T amp may be better than the setup I described above. So now I'm thinking I could sell the Parasound gear and go with this setup:
KingRex T20U Amplifier & PSU
KingRex Preamplifier
My only concern with this is the amp's power output. Seems those Infinity speakers I listed above would like more power than 13W@8 ohms, Which the T-20U is RATED AT. However, it does state that "KingRex T20 AMP has more power compared with the original T-AMP with the loudspeakers of average sensitivity (86~90dB, 4~8Ohms). You can easily reach levels comparable to vivid performances in medium space." in the description.
The only other option I could use would be to eliminate the M-Audio soundcard from the equation and go with a KingRex UD-01 DAC and PSU to use with my Parasound gear.
So I'd like to know, if the goal is to set up a computer to be used as a music server, which method described above do you think is the best option to implement in a medium sized room? The sale going on at Audiomagus ends at midnight on Sunday. Any suggestions or advice would be greatly appreciated, thanks.
