AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › Roku or DVD/Blu-ray player for netflix?
post #1 of 9
I switched from Charter cable and TiVo to DirecTV a few months ago and I miss the Netflix capability of the TiVo. I'm contemplating getting the Roku but, I wonder if I should go for a Blu-ray or DVD player with the same capability. Btw, I currently own an OPPO BDP-83 so I really don't need another player but, I thought I would get some "professional" opinions.
post #2 of 9
I have a Roku and like it but If I did not and had a BDP-83 I think I would still just get the Roku because it is the cheapest way to get Netflix to the TV., but if I had money to burn I might get the LG BD390 which does Netflix, YouTube, CinemaNow and more plus they just added Vudu. LG just keeps adding features to that player it does a lot if you never use the Blu-ray.
post #3 of 9
I was facing the same decision and since I didn't yet have a blu-ray player I purchased a Samsung BD-1590 for $180 at Samsclub. I am very pleased with the Netflix capability. It plays both SD and HD Netflix material well. I don't have a Roku player to directly compare with but I have heard they perform well also. Good luck.
Jay
post #4 of 9
It happens that I own all three of the Netflix streaming devices mentioned in this thread -- the Samsung BD-1590, the LG BD390, and the Roku. They all do a decent job of streaming Netflix, assuming a fast enough connection. I suppose if one was shopping for a new blu-ray player and also wanted Netflix streaming, either of the blu-ray units would be the most cost-effective solution. But the Roku has a lot going for it.
Here's what I like and don't like about each:
LG 390 - the good:
  • Only device of the three with VUDU, high-quality 1080p streaming;
  • Includes YouTube streaming in addition to Netflix (also has CinemaNow, but service not competitive with Amazon's);
  • Can stream photos and videos wirelessly from your PC;
  • Nicely designed player; clean, understandable on-screen interface;
  • WI-FI included
LG 390 - the not-so-good:
  • No Pandora (included on Samsung device; soon to be included on Roku);
  • Its WIFI doesn't seem to work that well in my setup (so I connected it to wired Ethernet; performance much improved, comparable to Samsung via Ethernet or Roku via Ethernet or WIFI)
Samsung BD-1590 - the good:
  • Includes Pandora in addition to Netflix;
  • Also includes YouTube (with firmware upgrade);
  • About 1/3 cheaper than LG 390
Samsung BD-1590 - the not-so-good:
  • On screen interface more confusing, less intuitive than LG product;
  • No built-in WIFI (its an $80 option);
  • Noisy player -- sounds clunky, especially when you first turn it on.
Roku - the good:
  • Clean, intuitive, responsive interface;
  • Simple, easy to use remote;
  • Ethernet and WIFI built in (wireless networking was easy to set up, and works well);
  • Includes Amazon Video on Demand in addition to Netflix;
  • Rapid startup (since its not also trying to be a blu-ray player);
  • Device will soon add up to ten additional streaming services -- confirmed and/or rumored to include Revision3, Mediafly, Blip.tv, Flickr, Pandora, others;
  • $99.99 -- with a 30-day money back guarantee;
  • 1 year warranty both parts and labor (note: both the Samsung and LG players have only a 1-year parts/30-day labor warranty -- a concern on my end, as my first blu-ray player, a Samsung 1500, died after nine months).
Roku - the not-so-good:
  • YouTube apparently not one of the services that will be added soon.
  • It's not a blu-ray player (but you knew that)
I thought for a while that the proliferation of blu-ray players that do streaming and their declining prices might make the Roku less competitive. But Roku's imminent addition of a number of additional streaming services adds a lot of value for this user. It's a simple, elegant little box that just works.
Roku has just come out with two additional models in addition to its original $99 model: a budget $79.99 unit with SD only and no HDMI out, and a deluxe $129.99 unit that adds 802.11n networking, and a USB port designated for future use.
There's one more possible downside to the Roku: if your monitor or AV receiver has two HDMI inputs, and you're using one for a blu-ray player and another for a DVR or a gaming device, you'll be out of HDMI ports and have to connect the Roku some other way. I solved that problem by buying a manual 2 x 1 HDMI switcher for about $16 from monoprice (which worked just fine -- though I later upgraded to a 4 x 1 HDMI switcher with remote for about $30).
post #5 of 9
I'm going to replace my Roku player with a PS3 slim
- games
- reference blue-ray player
- Netflix player (announced)
- Access to Hulu and other sources thru PlayOn
post #6 of 9
Rick, did you notice any difference in video performance, sd or hd, between any of the three players? Thanks.
post #7 of 9
There is not all that much HD content available for Netflix Instant Download, but I've watched a few HD titles, and lots of SD flicks, and I don't see much difference between any of the three devices in terms of video quality, when each is getting a good signal. On all three, what Netflix calls HD can't compare to blu-ray or even what your satellite or cable provider calls HD -- at its best, it's maybe a little better than standard DVD. SD quality ranges from a little worse than standard DVD to really bad VHS -- comparably bad on all three devices. I wish I could have really done an accurate A-B (or A-B-C) comparison -- hard to do with my setup -- but I can still say pretty confidently that the differences in video quality, if any, are subtle. As I mentioned, the LG 390 did look really lousy (grainy, etc.) when I connected it via WIFI, as compared to the Roku connected via WIFI. I tried moving both the Roku and LG players to different locations, and I never got a decent picture from the LG via its WIFI Connection. I'd have taken the LG back, except that when I connected it via an ethernet cable, the picture seemed about equivalent to the Roku. I'm not saying your experience would be the same -- though I'm no expert, I think there could be a lot of reasons why a particular WIFI device might not work well in one enviroment, but might work in another.
On a related subject: if I'd known Netflix was coming to the PS3, I might have waited and considered that option as well -- it'll be interesting to hear how that works out...
post #8 of 9
I really appreciate the info. Like the op, I've got a bdp-83 and I never noticed a real difference in sd dvd's until I had this player. So I was wondering if any of the three you used were noticeably better than the others. Thanks again for the help.
post #9 of 9
LG 390 - the good:
Hi Rick,
Have you done much streaming from your PC to the 390? I currently stream to my PS3 and although some 1080p and 720p material plays just fine (I have WM 11 running on my PC) some material gets "stuck" after the first 3 seconds. I'm not sure if this is an encoding problem or a Ps3 not liking WM11 problem. That said, I would like to hear if you or anybody else has experienced issues streaming video to the 390. I normally stream M2TS, AVI and MPG files (the PS3 does not support straight MKV).
