AVS › AVS Forum › Video Components › Home Theater Computers › ATI Radeon HD 5800, 5700 and 5600 Series Thread: Supporting HD Audio Bitstreaming!
ATI Radeon HD 5800, 5700 and 5600 Series Thread: Supporting HD Audio Bitstreaming! - Page 30
post #871 of 7498
Originally Posted by SamuriHL View Post
Yea, 130 and above are fine on 7. I couldn't run 130 because it broke TMT3 140 and above. But 131 seems to have fixed the side by side issue for some people. (I have tmt3 160 and tmt2 131 running side by side which is nice). I just took the audio file from 125 and dropped it in over the 131 file and all is well. ReClock is reporting 48/24 so it's all good. I'm running it on 7 x64.
SamuriHL - can you share the name of the file(s) you copied from 125 to 131?
post #872 of 7498
Originally Posted by kobestonecold View Post
is this mean this 5xxx series no good for the blu ray. The separate sound card auren Hometheatre HD + powerdvd 9 much better for blu ray playback.
I'm not sure what combination is best for Blu-ray playback. To me, being able to bitstream the HD audio codecs is important, and proper 24 fps video is important. TMT3 is good, and it is much better than my last experience with PDVD. I do have a Xonar HDAV to bitstream the audio with TMT3. Combinations I've tried:
Nvidia 9800 GT or GTX 260 + Xonar HDAV, where do I start? Massive lip sync problems at 24 Hz. Over 6 months of crappy video drivers, and I've tried lots of different versions. Every time I try to change refresh rates between 23/24 and 60 Hz, it is at least a 30 second event. And many times it doesn't even change the refresh rate, so I have to try 5 or 10 times before it will actually change! And there is always a multi second delay when toggling Vista Media Center between windowed and full screen mode. Nvidia has lost me.
Intel G45 IGP + Xonar HDAV, very close. Perfect lip sync at 24 Hz or 60 Hz, and the drivers have no problem switching between the resolutions. But every so often during BD playback, there is a very brief video glitch, probably due to the 24 Hz not being exactly 23.976. Toggling Vista Media Center between windowed/full screen is much faster than with Nvidia.
ATI 5770 + Xonar HDAV, can't select 24 Hz. Sure, a driver update could fix that, but I'm waiting, and my return window is counting down. Watching a movie at 59 Hz with TMT3 and everything played OK, other than the screen saver kicking in. ATI, this is your opportunity to impress me. This is the first time that I've bought an ATI card in many years.
post #873 of 7498
ASAudioHD.ax
post #874 of 7498
Have you tried 32 bit OS? I would say that 64 bit using TMT is NOT rock solid nor probably are the ATI drivers... Which both must work in conjunction with each other..
It wouldnt hurt to give it a try to see if it clears up your stability issues.
Originally Posted by LsRamAir View Post
The card is going back to newegg.
Seriously... I tried everything. even a fresh Win7RTM format.
I thought everything was perfect once i got the reinstall done, and the 9.11 drivers on. I had 23hz, 7.1 PCM with correct channel mappings, Super fast gaming and overall goodness.
BUT THEN when i started playing BD rips with TMT3 it would randomly freeze. Like hold the power button down style. Either with a black screen or a weird red color. This happened within the first few minutes of playback.
I popped the 4670 back in and VOILA everything is perfect again.
I hope to buy one again later on when the bugs are worked out. I will keep up on this thread's progress. if anyone has an fairly identical setup as me and can confirm everything working PLEASE help me out.
5770 via HDMI to receiver to LCD TV. Windows7 RTM x64. TMT3 .160 playing back BD Rips (.iso or .TS). Successful 23HZ option under refresh rates.
post #875 of 7498
I very much disagree with that statement. I run TMT3 on 2 64 bit machines and have zero problems with it. One is a 4850 doing 24Hz (not 23 like some people are trying) and the other is my 5870 doing 60Hz. Both are rock solid on W7 X64. I don't think 32 bit vs 64 bit has anything to do with it.
post #876 of 7498
Originally Posted by cfryer View Post
PowerDVD Ultra 9 patch 2201 is available from within PowerDVD but not from the website. Don't know if this patch includes bitstreaming on the ATI 5xxx series. I don't have reciever that will decode the lossless formats.
i applied that patch and bitstreaming is still not working in POWERDVD.....
post #877 of 7498
The waiting is hard, I know. But it s all we can do until Slysoft, Arcsoft, Cyberlink or the MPC-HC team comes up with THE solution.
post #878 of 7498
I have the patch and sadly, no, it does not bitstream uncompressed sound to receiver.
post #879 of 7498
SIGH. Now I guess we wait another few weeks to see if it gets released. I truly hope for Cyberlink's sake that when it's released it simply works flawlessly out the gate. Otherwise there's going to be a backlash like they've never seen before. I'd really like to see them make people happy and release a new feature (i.e. ATI bitstreaming) that simply works from day 1. However, if they keep pushing it back someone else will end up beating them to the punch. Not an enviable position to be in for them.
post #880 of 7498
I have the new WHQL Catalyst 9.10 drivers downloaded, but wont be home to try them until tonight.
Please O Please let them do 23Hz and stable video acceleration with TMT3!!!
Anyone available to try them today sooner?
post #881 of 7498
They're out? Guess I gotta get upgrading.
post #882 of 7498
post #883 of 7498
It looks like Catalyst 9.10 does not support HD 5700 Series.
1. No "HD 5700" in CW_83742.inf. ("HD 5800 Series" is there, however.) (BTW CL_83742.inf is "Longhorn" (Vista).)
2. The graphics driver cannot be installed in my HD 5750 system (only HDMI audio driver and CCC are installed).
Update
Non-support for HD 5700 Series is official: Catalyst 9.10 Release Notes (uploaded later).
post #884 of 7498
The 5xxx page still lists the 5xxx specific driver from 10/13. This can't be good.
post #885 of 7498
Crap! Man they need to start getting it togethor with their drivers.
post #886 of 7498
Even if it has the 5800 series in there, the main page still points us to the 10/13 driver page. So, something's not quite right. I've yet to try installing it on my 5870. I may do so in a little bit.
post #887 of 7498
I think you guy's bought that card a few weeks too early.
post #888 of 7498
PowerDVD will not support bitstreaming ATI 5XXX anytime soon because their are supporting Auren home theatre HD at the moment. Do you think Auren will be that happy if they let PowerDVD work on ATI bitstreaming? NOPE
Lucky i got Auren home theatre HD + powerdvd 9 now and really happy with it, i don't want to wait months for the damn bitstreaming.
post #889 of 7498
That's quite a stretch to make that claim. We've seen pictures of it working in September on reviewer's systems. They've said the holdup is in testing. Maybe they found a bug. I pleaded with CyberlinkUSA on this very thread to not release it unless it works. Maybe you can blame me for the lack of a release. (Yea, right, like they listen to me. LOL) I'm guessing they found an issue and maybe they did take my advice and only will release it once it actually works. Who knows. But I wouldn't bring Auzentech into this. They have nothing to do with the lack of a release IMO.
post #890 of 7498
Agreed.
post #891 of 7498
Huh? It's been officially announced that PowerDVD9 will be the software to support DTS-MA and TrueHD for the ATi 5xxx cards.
post #892 of 7498
Just to be clear about it, has it been officially announced by Cyberlink yet? I can't find any reference to bitstreaming with the ATI cards in the Cyberlink PDVD9 page.
post #893 of 7498
Hasn't Tom (CLUSA) said it was going to be supported?
post #894 of 7498
Yes, but I'm looking for something "more official". Can't find anything in Cyberlink Press Room either.
post #895 of 7498
post #896 of 7498
Lack of 5700 series support in the new drivers is a JOKE!!!
can we mod the .inf to include that string? they do it to every nvidia driver and it works great.
help?
post #897 of 7498
Tomshardware didn't just create its own drivers in order to get it working with PowerDVD9 - Cyberlink provided the drivers to them. Obviously Cyberlink has the driver and is working on it.
And if you look at the link from jgillispie, it was officially announced on the USS Hornet in a press release. And Tomshardware spoke directly to Cyberlink and got beta drivers from them to confirm it does work.
It's a minor part of what the 5000 series is about and that's probably why it is hard to find any press release talking about it.
post #898 of 7498
Does this mean I should not order my 5750 tonight? I want to add it to my new HTPC and be able to watch, rip my blu-rays.
Confused. If not 5750, then what??
post #899 of 7498
What is causing your confusion? The fact that 9.10 doesn't support it? I'm sure that'll get fixed at some point soon. That card may not be 100% ready for prime time but it'll get there soon. If you're looking for a new card, it'd be a good one.
post #900 of 7498
Thanks Sam. You are right. Will order it tonight.
Well, after I figure out what tuner card to get. Thats all I need to complete my parts for the HTPC. I know its not the right thread, but,,,,
We dont have cable. Have satellite and of course OTA. Is Hauppage the way to go? There are a couple cards listed on the famous 85 page but really need a push on a decision.
