AVS › AVS Forum › Audio › Speakers › Need some help with home theater choices!
post #1 of 5
My budget is 4k at the most which will include everything minus a television since I already have that. I prewired everything for a 7.1 setup as the house was being built. The dimensions of the living room are 17x25. Although since I left out the walls for the 4th bedroom it now is 17x36. As you will see hopefully in the pictures below the area where the living room is. I am writing this from work as I do not have internet at my house currently. I have updated pictures with the couches and tv mounted, etc so will try and get those up soon.
post #2 of 5
I was looking at yamaha as a possible solution for speakers. So many different types out there and I have no place close that I can listen to anything to help with a decision. This is what I have looked at so far with yamaha....
NS - C444 center channel
NS - C777 floor standing(two)
NS - C333 side and rear(four)
subwoofer....?? not sure.
As for the receiver I am thinking either denon or onkyo. Something else I can get for better all around setup?
post #3 of 5
Nice looking room, i built my house with a seperate media room just over 2 years ago. Sound Proof walls, Floating raised floor, 120" projector, sound panels at 1rst reflection points , column style Bass traps, dual 18" infinite baffle sub system all done on the cheap (DIY) I learned most of it on this forum, great place!
av123 currently has a huge sale on their awesome 5 speaker Rocket package which I own and love, under $2K for speakers that retail for $3500. The mains (RS850s) sound is simialr to Paradigm studio 100's($2600 a pair) with a little cleaner bottom end and slightly better imaging IMO. The center the RSC200 nicknamed Bigfoot has a well known rep for being a monster of center size and sound.
Pioneer Elite, Marantz, Denon, Yamaha all make good receivers, i currently have Yamaha but will soon upgrade to a Pioneer Elite or Marantz. All good choices.
That tile floor is gonna give you fits to get clean sound, reflections can really muddy up the best speakers, you'll get the sound from your speakers (good) along with the same sounds bouncing off this and that all traveling different distances reaching your ears at different times (bad) Kinda like when you pull up at a drive through and you can hear the sound of your engine bouncing off the resteraunt wall.
You may think your center sucks because you can't make out the words when the whole time this is what's happening, your hearing each word several times within milli seconds all jumbled up.
Rugs and furniture do help alot, Accousitc sound panels are probably the best investment I ever made. I made them myself, but it really cleaned everything up they can absorb sounds much lower that carpet and rugs alone. It was like I had an entire new sound system.
Try the clap test, if you clap and you hear an echo (bad), if you hear a clap and then instant silence (good)
Many people overlook this but if you want the absolute best HT experience you can get, it'll make morre of a difference in your room than most any other HT decision you'll make.
post #4 of 5
Thank you for the nice reply!! I will check out av123 later tonight for sure!!
I did the clap test last night and did not have an echo. Although after the clap the sound kinda stayed within the room for a second or so and then went away, but no echo. In the front of the room I will end up getting a pool table in the near future. I as well will be getting a 12x12 area rug in the future so that will help with the sound. I wish I could have done up a media room, but just didnt have funds for a room as such.
Acoustic sound panels you say? I will have to look into those as well. Have any links?
Thanks for all the information as this is what I was needing. I knew the tile floor would make for a "live" room, but hope I wont get any echos.
post #5 of 5
That package at AVS123 looks great! The only downfall is the 450's are too large for my room. If you look at the picture with the fans in it I would need speakers to mount from the ceiling instead of floor stands. I only say this because that is a walkway behind the couch. I wish I could use them, but from what I am looking at right now this is a problem.
Then again....I will have to measure there may be enough walking room to have floor standing speakers. What stinks is the wire ran out of the ceiling would look funky coming down.
  Back to Forum: Speakers
