Getting a separate box for the HDTV looked like the solution to me at last if I want to use SR5004 as a solo switching device and up-convert/scale SD to HD.
I also figured a bit disappointing conclusion about my connectivity done by installer from Dish Network. The DVR I have have is Dish ViP722 (http://www.dishnetwork.com/downloads...2_brochure.pdf). The specs says TV1 as HD and TV2 as SD. The installer from Dish network installed the other way round. So I have HDMI connectivity at the tube TV1 and coax to plasma TV2. Well, I don't know where to go from here. I guess I will give Dish network a call. This installation was done a while ago and I had no issues with the signal. Even now, when I change the same channel from SD to HD, it looks better!!! I don't know how? (The tuner at my HDTV might be a SD tuner as well!!)
HDMI is only limited to TV1 and the remote for TV1 is IR for changing the channels. So changing the outputs from back of the receiver to TVs won't help even if I use wireless HDMI transmitter. A big mess.
I have both Dish and Verizon services, and all the HD channels in Dish I can get from Verizon. All the channels not available in Verizon is all SD anyway. Switching channels seems like a workable idea for now.
I am glad I got 5004 and these all came to the surface, otherwise I would have never known about any of these. Thank you for all the responses Lost!
I replaced the amp and went to shower and tadaa, no hot left side! Left side of the amp was 1cm to the center speaker, right side is open. My last amp did not generate any heat in the same position, seemingly 5004 depends more on the side vents. So, no heat problem after all.
