Hi all and a happy new year!
I am new here and i have just bite the bullet
, i am from Slovenia by the way. After many many many hours of reading this forum i decidede to replace my 5 years old sr 5500 with sr 5004 (i wasnt sure to buy a 5004 or 6004 but after reading the diferences i got 5004, and there was yamaha 1065 and denon 2310 in play). Man i love this receiver it really rocks and it has that lovely pure sound it is a difference with between that and my old sr 5500. I hope mine wont do that famous POP
, but for now i dont have any hdmi equipment and i will get it next year with blu ray player. I have a question about audyssey. I have done auto setup but it has lovered my output considerably (fr -8,5, fl -10, c -7,5, sur -12 and sub -10) i wonder if there is something i can do to get closer to 0 db (i know i can lover the sub but what about other speakers?). And is there a setting to see what crossover has receiver put on speakers (front and center are large, and sur are small but lpf/hpf is at 160 hz, so if i set front and center to small does that mean the crossover to front is at 160 hz?, it is a bit high). Is it possible to store different settings for auto setup and manual setup (for instance if i disable audyssey will the speaker distances and output be the same or i can set it different (with manual test tone). I will have some more questions thats for sure
, i hope anyone can help me, and thanks in advance. And the last questions, as it seems some receivers have trouble with hdmi are there any infos what manufacturing codes are affected?
