AVS › AVS Forum › Audio › Receivers, Amps, and Processors › *Official* Pioneer Elite VSX-21/23THX Owners Thread
*Official* Pioneer Elite VSX-21/23THX Owners Thread - Page 60
post #1771 of 3493
Originally Posted by ccotenj View Post
to each his own... but to make a blanket statement of "sub for music = bad" is incorrect... regardless of what "many audiophiles" might think...
I guess we agree to disagree. In most listening environments which we are all using (a room in our house) a sub will typically distort the mids and high and therefor music is not reproduced properly. As I mentioned this is not only coming from me, there are many articles, interviews, documents authored by audio engineers and musicians explaining in better detail of what I mean. I have yet to read an article from a musician that states they like how a sub re produces their music.
But like you said... to each his own. Your own ears are the true test to any sound.
post #1772 of 3493
Originally Posted by Mikes2cents View Post
it would be the bees knees if this unit would save different speaker setups into the MCACC memories. It does not and we end up posting about this over and over. My intention is to make folks aware of this so when they are researching a purchase they have some info at hand from real users before they buy so they know what they are getting. Nothing more, and certainly not to argue.
Yes this would be a beautiful feature.
post #1773 of 3493
links please...
a correctly integrated sub will reproduce the sound "correctly".... "distort the mids and highs"??? please.... exactly WHY do you think a sub would distort the mids and highs, yet reproducing those very same frequencies from a full range speaker wouldn't?
audiophile mythology at work here... more out of date thoughts propagated with no actual basis in fact...
post #1774 of 3493
Originally Posted by njstone View Post
Okay, so I did what was suggested in order to get my wireless headphones to work via the receiver's optical output:
I set up a new input connection for my PS3, this time instead of just assigning the HDMI 3 input, I also assigned the Optical 3 input (optical 3 is connected to my PS3).
When the receiver is on this setting, I get NO SOUND over the headphones or speakers (i.e. it seems that the optical isn't going through) ... but here's the strange thing, when I'm switching inputs, I do get audio through BOTH for a split second. Also, when I switch to the GUI screen, I get audio through BOTH!
So what am I missing? There must be some setting on the receiver I need to change, but I can't think what it is. (Kurolink is off)
I think this is what your missing:
See page 61 of your manual.
Choosing the input signal
From your remote, cycle the input signal to Digital.
You should only have to do this once. Since you have HDMI connected, Initially, it will assume audio is via HDMI as well.
post #1775 of 3493
Im also having a hard time understanding why a quality, properly tuned/crossovered sub would have any effect at all on the mids and highs? If that sub was built into the Mains instead of sitting right beside them, youre saying things would be better?
post #1776 of 3493
Originally Posted by david_nc View Post
It does not. I'm going to work around this by connecting component cables from the sat. box to the TV. Another option is to run your HDMI from the box to the TV and an optical digital from the TV to the receiver.
Don't let that keep you from going with the 21. I was going to buy a 21, but 23's are very little more and have a zone 3 that I wanted.
Thanks for the info. I was really hoping to find a receiver that would allow me to watch cable without having it on.
post #1777 of 3493
I just got my Harmony One yesterday and was able to set-up the correct devices (Pionner HDTV, Pioneer AVR, Oppo Blu-ray). Got the initial activities in place for watching TV, watching Blu-Ray/DVD, but with a slight problem.
It seems that my Pioneer VSX-1019AH-K isnt able to switch to the correct assigned input when I press an activity on the remote. For instance, if I have just watched TV with the AVR set on TV/SAT input, then press "Watch DVD" on the remote, the remote does everything properly, except the AVR input remains on TV/SAT. Vice versa, if the AVR input was initially set on BD (Blu-ray Disc), and I then press "Watch TV" on the remote, the AVR input remains on BD.
I know the inputs are set-up properly in the software because I checked them again. And also, if I use the Harmony Remote Assistant to correct the problem, it quickly switched to the desired input. But then if I turn everything off and start all over again, I get the same issue.
Any ideas before I call tech support?
post #1778 of 3493
to clarify, is the system turned off in-between? i.e. you were watching tv, turned everything off, and then came back and watched a dvd later?
or
you are watching tv, and hit "watch dvd" without turning the system off?
that will help us to debug...
post #1779 of 3493
The feel of live music is what we all strive for. Every "professional" quality PA I have ever seen incorporates subwoofers. So, why is that?
post #1780 of 3493
or
Yes. I have just been testing the remotes function - not really doing any real watching. But anyway, so far I think I have always turned all components off in between trying the "Watch TV" and "Watch DVD" commands on the remote.
post #1781 of 3493
ok... i believe that you need to increase the power on delay for the avr device... post back if you need instructions to do that...
post #1782 of 3493
Power-on delay default is currently set to 1500ms.
Any suggestion for what to try?
What about all these other delays? Inter-key Delay, Input Delay, Inter-Device Delay?
post #1783 of 3493
bump it up 500 ms and see if that helps... if not, bump it up another 500...
let's start with that...
post #1784 of 3493
Hey
I have a Pioneer Elite VSX-23TXH.
I am going to be moving to England in a couple of months and i am hoping to take the receiver with me.
Will i be able to use it over there?
My friend took his PS3 over there and he said he plugged it in and it worked fine.
Would this be the same for the VSX-23?
If not is there anything i can buy to make it work?
thanks for any help.
post #1785 of 3493
Also, on the PS3, you need to set the audio up to be output over both outputs at the same time. Otherwise, it will only use the primary output (HDMI) for audio.
post #1786 of 3493
Originally Posted by acejhtwo View Post
Hey
The specs in the manual say 110V AC, 60Hz. Generally, if a unit can be used across the pond, it'll say 110-240V, 50-60Hz.
You would need an inverter/converter to get it to work.
Computers, on the other hand, generally have internationally-capable power supplies and just need the correct plug to work (especially laptops and other units with external transformers), or need a switch flipped.
post #1787 of 3493
Well I did wind up calling tech support. i did bump up the power on delay 500ms as you suggested. But he also suggested to bump up the input delay and inter device delay each by 500ms and the inter key delay by 100ms.
That combination of things seems to have fixed the problem. Perhaps it could have been corrected with just the power on delay or some other combination, but I did not try anything else yet.
post #1788 of 3493
I don't know what models do the pass through without turning the unit on. I will say that I refuse to pass video through my receiver for the wife approval and ease of use factor, not to mention my Sammy has plenty of connections and does a great converting job to what it likes best. I don't think the Pioneer knows any better what the TV likes.
So I am the commander of the surround and she can just watch regular cable TV like she likes. Win win for me and these Elites sound sooooo good. Your call.
post #1789 of 3493
It's almost irrelevant if you connect it like I mentioned. HDMI from cable box to TV, optical digital (audio) from TV to receiver. You'll get video and audio to the TV without the receiver being on. If you want to hear the sound through the receiver, just turn it on and select the input that's assigned to the optical input.
post #1790 of 3493
Originally Posted by tima94930 View Post
This is kind of funny. That page took a long time to load with all its pics, and the part that was visible first was your message:
http://www.avsforum.com/avs-vb/showt...7#post18103897
Thanks. That thread was kind of languishing away there. Pics say a thousand words and I for one do not care to read about what someone says they have. I like pictures of good clean setups because they spark ideas for me. I will say that some of the folks posting have some systems that are simply to be drooled over. I just cannot imagine making much more sound than I can now, but if I had the $$$ I probably would.
post #1791 of 3493
Except for a slight delay or lip synch issue I noticed. I just run optical from my cable box and other items to my AVR, works better for me, and that is just my experience.
post #1792 of 3493
THANK YOU!!!!!!!!
Now I just have to figure out the HDMI handshaking issue with my DISH receiver, and I'm all set (I know there are posts on that, so I'll read up on it).
post #1793 of 3493
That's how I have it set up now with my Pioneer Elite vsx-27tx. It doesn't have HDMI or component, so I connect the cable box and blue-ray directly to my TV using HDMI and run optical to the receiver. I would stick with this setup if it wasn't for the receiver's preamp outputs being dead. Now I have no bass because the sub doesn't get a signal. Wife says I can buy myself a new receiver for Valentine's Day.
I'm done paying $1000+ for receivers that become obsolete within years, but maybe that's what I have to do to get the feature I need. Well, I need to make a decision soon before I do something to upset the wife and have my gift revoked.
post #1794 of 3493
Ok... maybe a dumb question. Is the blue light supposed to stay on when the receiver is off/in standby? It comes on when I power up the receiver, then goes off when I turn the receiver off. All my other Pioneer equipment has the light on when it is in standby.
post #1795 of 3493
If KURO Link is set to "off", then the receiver has two power modes: On and Off. If KURO Link is set to "on", then the receiver has three power modes: On, Standby, and Off.
That would bug the living daylights out of me if the lights stayed on all the time in standby. My TVs and my PS3 each have a very small, diffused red LED that is on in standby mode, but a piercing bright blue LED in standby would drive me nuts.
post #1796 of 3493
Thanks Client. I do have KURO Link off. I just wanted to be sure that everything was ok with the receiver. One more thing. I have not had the time yet to tinker with the 23. Last night, I listened to some music (CD) and it just didn't sound great. Wouldn't it be so much easier if the receiver just had a treble and bass adjustment option? I am just not that tech savy. What do you suggest I do to get music to sound better?
post #1797 of 3493
It is safe to buy an Elite receiver in ebay?, i can only purchase it online because i live in Colombia and i have the way to import it, so it is a safe option?.
http://cgi.ebay.com/Pioneer-Elite-VS...item35a6f5ecff
post #1798 of 3493
If you haven't run the MCACC setup yet, be sure to do that. In these days of advanced electronics and sound processing, the traditional "treble" and "bass" analog knobs are pretty much obsolete. For that matter, since the days of equalizers, the amount of control over tonality is much better than simple "bass" and "treble" knobs. The receivers have this built in electronically now, so it takes a little more digging to get to it. I suggest running the MCACC and seeing what effect it has. The post-processing results should be viewable on the on-screen display on your TV, showing the EQ and channel level adjustments that it made to everything. In the end, even though there are many different opinions on how sound "should" be heard, it's all a matter of personal taste. (see also: last 2 pages of this thread. )
Safe? I suppose, if it's from a trusted seller. Since you're exporting it to Colombia, I'm not sure if there would be a factory warranty on it anyway, so the fact that the factory warranty is voided by buying it online is of little consequence.
I would, however, hesitate to buy an item from a seller who doesn't even have the correct product image in their listing. The receiver in the picture on that listing appears to be an SC model or something, but certainly isn't a VSX-23.
But that's just me.
post #1799 of 3493
But that's just me.
The receiver in that picture for what i can see is an SC-07, but looking at his reputation is very high and i don´t think there would be a problen at all, and like you say the warranty is not a problem to me because of the importation of the item.
Copy from the seller:
We are not responsible for typographical errors. The photographs of some accessories may not reflect the actual item shipped. We reserve the right to substitute accessories for similar ones of equal or greater value.
If you look detailed the score of that seller, i think half of what i sold was receivers, and all with good calification.
post #1800 of 3493
Anyone here have there Elite 21 connected to a video processor?
I have an older KeyDigital iSync Pro. I had my DISH receiver connected to my Elite 21 via HDMI (at 1080i), then to the iSync. When I apply power to the Pioneer. the iSync would flip out, cycling between 'no input' and 'Standby' mode.
I'm wondering if there might be an hdmi issue at work here. I could cycle different eq on/off and everything would eventually work, but what a pain!
