AVS › AVS Forum › Audio › Receivers, Amps, and Processors › *Official* Pioneer Elite VSX-21/23THX Owners Thread
*Official* Pioneer Elite VSX-21/23THX Owners Thread - Page 61
post #1801 of 3493
I have a 21 and was wondering how to switch inputs with the receiver on standby?
I'm trying to setup activities on my Harmony 880 to watch TV and movies with the receiver off. I have everything hooked up via HDMI to the receiver (BDP, cable STB, and TV). Kuro Link is "on" so when the TV powers up the 21 goes to standby. But if I want to watch a movie, the 21 wont switch to the "BD" input. The only way is to turn on the 21 fully and switch inputs manually.
There are times when I don't need the surround speakers on (ie nightime viewing) and getting the receiver to cooperate in this manner has been a head scratcher.
post #1802 of 3493
My receiver is in service right now, I miss it already ;_;
post #1803 of 3493
Are both your TV and your BD player KURO-compatible? There won't be any pass-through in standby mode unless they are both KURO-link compatible(which, I understand, is slightly contrary to what we have told other people in recent posts). Unfortunately, the owner's manual isn't very forthcoming on how this pass-through works, but it appears that the KURO link should identify that an input was powered on, and switch to that component, whether the receiver is on or in standby.
Can't be much more help than that, as I don't have any KURO devices other than my receiver. All of my inputs and output are Sony devices (PS3, DVD changer, TV).
post #1804 of 3493
Originally Posted by dmspen View Post
Anyone here have there Elite 21 connected to a video processor?
I have an older KeyDigital iSync Pro. I had my DISH receiver connected to my Elite 21 via HDMI (at 1080i), then to the iSync. When I apply power to the Pioneer. the iSync would flip out, cycling between 'no input' and 'Standby' mode.
I'm wondering if there might be an hdmi issue at work here. I could cycle different eq on/off and everything would eventually work, but what a pain!
I have to ask this, since everyone else must be thinking it, and I have no filter, but...
Why are you bothering to pass your Elite's video through another video processor when the Elite already has an Anchor Bay 1015 in it? It does switching, upconverting, and the whole lot. What possible good could a 4 year-old external video processor do after it goes through the Elite?
post #1805 of 3493
A couple of newbie questions...what is the best wiring approach to having TV viewing capability (Pio 6020 FD) w/o having have to have AVR (VSX-21TXH) powered on? I'm assuming Kuro Link can't help w/this but I could be wrong.
Two approaches I see are: HDMI signal split out of Motorola DVR STB..one side to TV and the other to VSX-21 and the other approach would be STB to TV via HDMI w/optical out to AVR. Do I possibly sacrifice PQ or audio processing choices at the AVR if the approach is to wire STB directly to TV via HDMI?
One last question...I've seen varying responses on the question of signal upconversion for SD signals out of STB...would using component hook-up from STB to AVR really provide a better image for SD content than going w/an STB-AVR HDMI hook-up that wouldn't touch the signal on the way to the TV?
Any help would be greatly appreciated..
post #1806 of 3493
It does pass-through initially when I switch from TV to BD but if I want to go back to TV, I haven't been able to find a way to do so without turning on the 21 fully and doing it manually.
The setup is when the TV powers on, the 21 goes from off to standby. The signal then passes-through. If I want to watch a movie and power on the BDP, the 21 senses the signal and is passed-through. Beyond that, I haven't found a way to switch it back. Powering off the BDP just gives me a blank screen.
My equipment:
Panasonic plasma S1
Panny BD60 player
Motorola DCH3200 STB
TIA.
post #1807 of 3493
My equipment:
Panasonic plasma S1
Panny BD60 player
TIA.
If, by "go back to the TV", you mean switch to the Motorola STB, which is hooked to the 21, then it can't be done. The only devices that can be passed through on the 21/23 while in standby are KURO-link devices.
Don't you just love HDCP and proprietary control formats?
post #1808 of 3493
I was trying not to respond to this (not because I don't want to, but because I have less experience with the need for this kind of setup), but since nobody else has so far...
Correct, KURO won't help, as a Motorola DVR STB isn't KURO-capable.
And, unless you have an HD-Audio-capable STB (which, AFAIK, doesn't exist), there should be no discernable loss of AQ by sending the signal via HDMI directly to the TV and then running optical to the receiver from the TV.
The only thing you'd be giving up in terms of processing choices is having to switch your TV between two different HDMI inputs depending on what you want to watch (TV vs AVR stuff). My primary TV only has one HDMI input, so, for me, everything goes through the AVR. I also live alone, without any wall neighbors, so it makes little difference to me if I use the AVR to listen to everything.
Also, if you're going to hook the STB directly to the TV via HDMI, there is very little to be gained by sending the A/V through the receiver when you want to use the receiver for audio, so there should be no need for a splitter, as it would only introduce unnecessary complexity and another potential point of failure.
As far as the upconversion of SD material, it's a crapshoot, from what I've found. Most TVs nowadays do a pretty decent job, and I think HDMI would be perfectly fine to do this for sending it from the STB direct to the TV.
post #1809 of 3493
Ok that makes sense. Looks like I'll have to connect the STB to the TV instead. I'll tweak a few things and post back here with any questions.
Thanks for the guidance.
post #1810 of 3493
Just wondering how the owners of the VSX-23TXH like it?
Im deciding between it and the Onkyo 707
Any help would be appreciated
post #1811 of 3493
I cannot speak for the Onkyo 707, no experience with it. I can say that my 23 makes beautiful surround. Like nothing I have heard anywhere aside from an actual theater. Even with some crappy speakers I hooked up at first. Now it just rocks with some better units. Just ordered another sub lol.
So MCACC has it's setup memory shortfalls that are well documented here, and the AVR has some other issues/bugs also documented, I am more than satisfied with mine. The minor (to me) problems with it are far surpassed with performance when you keep hookup simple and get it calibrated to your system.
This is a high tech piece of equipment trying to do a lot of things and it has some bugs. This is not at all unlike PCs were and are. Why is it we find it acceptable for computers to crash and have bugs, but we harp on a receiver that is trying to do a lot of things with different components?
Of course if the Onkyo does all these things without any issues then get that and I will STFU. I just don't know because my budget does not allow me to experiment.
KISS: Keep it simple stupid. Why run video through an amp when your TV can take the signal and convert it to what it can display best? When the STB or whatever source sends 1080P, my TV takes it and displays it, duh! Most all HDTVs have a processor in them that does what needs to be done to optimize whatever signal it gets for the display. So it is about getting the audio for me. A lot of posts/problems here can be resolved with this connection theory.
Yes my 23 has more HDMI inputs. I use none of them. For the money I decided to go with the 23 since it was little enough more and had zone three as well along with that beautiful face plate. Keep in mind the 21 and 23 are the current bottom of the line Elites. That means they are not budget but not high end either. Having said that, my 23 is high end enough for what I need.
post #1812 of 3493
I hear ya man. Im about 99% settled on the 23 for my system. Definitely the best looking receiver in this price range for sure.
What speakers are you currently using?
I just picked up paradigm monitor 9's for a 5.1
post #1813 of 3493
Nice. I am using Polk stuff. Just click on me and check my posts. I have recently posted pics of my setup in house. I am an advocate of price VS performance. Heck, sub #3 on the way here soon. Newegg made me a deal I could not refuse lol.
post #1814 of 3493
Can someone confirm this for me? Is pioneer currently working on a firmware update for the VSX 23TXH regarding the remote control cant power on issues? If so, does anyone know when the firmware will release and how to do it? Thanks in advance
post #1815 of 3493
hello everybody so i have had my 21 now for two months and yesterday i could not turn on with remote. not very happy since i had just sat down with my 11 month old to feed her. nonetheless it turned on when i got up to manually power on. is this power issue people are having with remote or could this be just a fluke? all has turned on since... until this morning when everything powered on, but no signal to tv. i could hear but until i switched through sources, from bd back to hdmi was when the picture finally showed up. like i said i have had this receiver for two months and first time this has happened. yesterday power and then today picture??? any advice?
post #1816 of 3493
Anyone else on the PQ comparison (HDMI versus component) of SD content through the VSX-21 to Pio 6020?
post #1817 of 3493
I don't seem to get much output to my surrounds...I have manually changed the outputs to the various speakers via the MCACC menu..this seems to help a bit, but at the expense on the sound level out of the mains.
Also, which of the audio processing modes will help pump up the output to the surrounds?
Thanks for any insights here.
post #1818 of 3493
I wouldn't stress / worry too much about the remote not being able to turn on the receiver. I've had my '23 almost 2 weeks and have NEVER had any problem with this. In fact, I've used the remote exclusively to turn the unit on and off to see if I have the problem. FWIW, mine was made in late November, if that has anything to do with it.
Not to discount those whose have this problem, but it doesn't seem to be universal. Like most things, you generally won't hear from those who don't have the problem.
post #1819 of 3493
Question. Is there a way to set the crossovers for each speaker? I have read the hand book from page 82 and on at least four times and cannot seem to see anything about. I have the 23.
Thanks for the help.
post #1820 of 3493
I can get the 21THX for only a little more than the 1019. I am familiar with most of the advanatages the Elite model has, but are there any advantages with the 1019 over the 21? Thanks.
post #1821 of 3493
Absolutely not. Get the 21.
post #1822 of 3493
Try turning on DRC or Midnight Mode. Midnight helps a lot.
post #1823 of 3493
Originally Posted by david_nc View Post
.....I've had my '23 almost 2 weeks and have NEVER had any problem with this. In fact, I've used the remote exclusively to turn the unit on and off to see if I have the problem. FWIW, mine was made in late November, if that has anything to do with it.
Almost 2 weeks eh? I hope your luck continues. Mine was flawless at first too. Then it happened, and it has been hit and miss ever since. Mostly it works. Tonight after work, I had to go push the button on the unit.
post #1824 of 3493
just got finished setting up my VSX-23TXH, its amazing except for one small snag, ive got my comcast HD box hooked up to it with HDMI, and the HD channels look and work great. however when i switch to any of the standard def channels, the tv says unsupported mode. however, it worked fine when the box was connected directly to the tv. is there some simple thing im not doing? or should i be thinking about exchanging it before the return period is up?
post #1825 of 3493
What he said. I too was looking at the 1019 then saw I could get the 21 for little more. I then found I could get the 23 for just a wee bit more than just getting the 21 and I ended up with the 23. The Elites will have better amps. My unit does not even begin to get hot. Well put together for heat dissipation.
post #1826 of 3493
I don't run any video including cable box through my 23 for a number of reasons, your problems being one of those. Connect it directly to your TV and run digital audio to the 23. Of course for those without a TV with multiple HDMI inputs, you probably need to go into the TV's menu and find a display setting that works. I don't know what TV you have so you will need to poke around in the setup and find what it is set at. I hope you can find a fix there, but the way I connect mine is a no brainer.
post #1827 of 3493
This came up earlier in the thread, probably in the page 50-52 range. It was related to the way the STB was converting the output signal and how it was being handled by the AVR. A quick search might help.
I, however, do not subscribe to the "only ever hook a STB directly to the TV" camp, mostly because a) my TV has only one HDMI, b) I don't have a STB, and c) the reasons given for doing it are usually specious at best. Unless you MUST be able to watch the STB without having the AVR on, it's much more simple to use the AVR for its intended design, controlling the flow of A/V for your entire system.
Of course, most of the problems with setups any more can be traced almost directly to DMCA and HDCP. You can thank the morons in the MPAA, RIAA, Washington, DC, etc. for that.
post #1828 of 3493
sorry i didnt put it up there in my first post, but my TV is a Samsung LNT4061FX, i DO have three HDMI ins, but like it was stated above, it would be nice to have it all running through the AVR. another issue is the reason why i upgraded to this unit in the first place. i had everything plugged into the tv and ran a toslink cable down to my old receiver how it was set up before, but as we know toslink can only handle two channels of PCM, so it basically makes it pointless to have surround. the tv doesnt have any other outputs for audio and the cable box is the same way, either two RCA jacks or toslink.
the main thing i find strange is how it worked fine when plugged directly into the tv. maybe im missing something in the manual, but it would seem as though when on an HDMI you cant change the video settings? every time i press it it says not available. and i did read most of this thread (sorry if i missed this issue, i made it through a few dozen pages at least) where it seems as though that is the case, that you can only change the settings on analog. but you would think that even in HDMI you can have resolutions less than 1080p, so the scaler has to do something, so wouldnt you then have a reason to get at the settings? i seem to think its something to do with improper scaling, but i could be wrong, thats why im askin
post #1829 of 3493
did you bring it in for the power on issue, if so what did the tech. say?
post #1830 of 3493
I said in a previos post I had 3 vsx 23's and all of them had the remote problem just after a few days out of the box while the kuro link is off.
